Step 61Handle/Electronics: Battery Case
Pour hot glue over these connections to insulate them and protect them from breaking off. You now have a power source for your hub.
Plug your camera into the USB hub and connect the battery case red and brown (+V and Ground) to the USB hub +V and Ground (red and brown) using alligator clips. The camera shutter should fire, and if the hub has an LED, it should light up. This will only work if you installed the custom firmware I discussed earlier.
| « Previous Step | View All Steps | Next Step » |
Add Comment
