Step 78Download Page Builder
Currently, this is alpha software. It makes a number of assumptions. It requires a powerful machine to work. You will be best off with at least 2 gigabytes of ram and up to ten gigabytes of free hard disk space. At some point, this will change, but likely not very soon.
While it is very easy to tell the software what to do, it takes a while to process so much image data. Page Builder may take more than 3 hours to process a 300 page book. Currently, we have to make a book into a couple smaller PDFs -- the reason being the way we make PDFs from Matlab. If anyone has Matlab code for good PDF printing, please contact us.
Download Page Builder for XP here.
Download Page Builder for Vista here.
Mac users will need a copy of Matlab, as we can't get a standalone version to work. The XP and Vista copies both include the source script, which was developed on a Mac and works fine..
UPDATE 2009/04/20: If you are having page order issues, please try this version, which also includes some imaging enhancements.
Only the XP version has been extensively tested.
Page Builder is Free Software. The sources are available. We are graduate students and have extremely limited time to support this software. So little time that we actually have no time. It is our hope that other people will help shoulder some of the development costs of this software.
| « Previous Step | View All Steps | Next Step » |
Consider the following alternative, until we get a free solution:
1) Using XnView to crop, resize, adjust brightness/contrast as a batch job. Download XnView from http://www.xnview.com/en/screenshots.html
As I was searching for a free solution, I found this XnView. I really liked the simplicity and speed of XnView. After the initial learning curve; I was able to create a batch process under the tools menu. At times, I found it even more convenient than PhotoShop Automated script (I’m not a graphics guru)
2) Rename the files for the left and the right camera, and merge them into one folder.
I first used spreadsheet to aid in renaming the files; later, I created script for this process. See my instructions here: http://www.mind2b.com/component/content/article/9-info/8-renaming-or-renumbering-camera-or-image-files.
3) I used Adobe Acrobat to create my PDF.
Perhaps someonelse can suggest a good free alternative.
http://danreetz.com/book_scanner/PgBldr2_XP.zip
Title: PgBldr4.exe - Unable To Locate Component
Message: This application has failed to start because mclmcrrt77.dll was not found. Re-installing the application may fix this problem
The readme.txt has the following to say:
...Ensure that the MATLAB Component
Runtime (MCR) is installed on target machines, and ensure you
have installed the correct version...
http://danreetz.com/book_scanner/PgBldr2_JPEG_XP.zip
This version gives you the option of JPG or PDF output. I strongly recommend using JPG output for the time being, and putting those JPGs together into a book using another application.
You'll need the Matlab Component Runtime to make it work. Unfortunately, it's 175mb, but I have no control over that. I'm uploading it here:
http://danreetz.com/book_scanner/MCRInstaller.exe
It will be finished uploading in about 20 minutes.
Re "manual mode", that is what you say to use in the instructables. I made all the settings as shown. But re "Focus should operate as normal unless you go into manual mode" -- I don't understand that, is there an alternative mode to use for this? Or maybe you can be in manual mode and choose either manual focus or auto focus?
A final question for now - when I push the switch, what should happen? Should the cameras take the photos, simultaneously, on that single click? Or should I have to click twice, once to focus and then again to shoot?
Thanks for your patience.
