Hi! I'm Stephanie, the blogger at Henry Happened . I have a bit of a DIY addiction and love to roam Home Depot for easy (and cheap) inspiration. Here's a simple project that screams "industrial chic!" :)
Last time I roamed the aisles at Home Depot I picked up this metal thingy. Ok, it's actually a hose clamp.
Its unique industrialness appealed to me. For $1.30, why not? (I also could not resist the 80 cent small version as a ring.)
Step 1: You Will Need
For your own bracelet, you will need:
- 1 hose clamp - the good news is that it's adjustable so you can tighten it to fit your wrist
- About a foot of 1/4 inch ribbon if you want to add some color
- E 6000 Glue
- Tweezers and bobby pins will also come in handy
lcastaño says: Nov 1, 2011. 3:02 PM
doesn't this rust your wrist, or turn green?
bluemoon6 says: Oct 18, 2011. 5:54 AM
What a great Idea--thanks for sharing!!!
mrq2u says: Sep 25, 2011. 9:55 AM
You can completely remove the screw assembly, then after carefully determining the right size you could fasten the ends together by threading and fastening small gauge wire through the two pieces to join them tightly, then cover the wire and ends by wrapping with coloured electrical tape.
janetsellers08 says: Sep 18, 2011. 8:46 AM
Cute idea, but how would you avoid getting banged up by the screw assembly part?
Henry Happened (author) in reply to janetsellers08Sep 19, 2011. 2:54 PM
I've worn it with a couple of other bracelets so they all jangle around together. It hasn't banged or hurt at all!
grannyjones says: Sep 18, 2011. 9:10 AM
Instead of ribbon, I would use a bit of colored silicone tape, or colored electrical tape--cut to size.
Henry Happened (author) in reply to grannyjonesSep 19, 2011. 2:54 PM
Yep, you can use just about anything that suits your fancy! :)
MsJaxFla says: Sep 18, 2011. 10:14 AM
Now, this I consider very worth my reading. I have purchased many of those hose clamps and never even thought of using one for a bracelet. Great idea and thank you so much. VERY CUTE. I will share this if you don't mind?
Sheryll & Critters.
Henry Happened (author) in reply to MsJaxFlaSep 19, 2011. 2:53 PM
Sure! Glad you like it! :)
regularityaudiolabs says: Sep 18, 2011. 11:04 PM
Be aware that hose clamps are very sharp edged and may cut into your wrist if caught on something. They also will not slide off if pulled. Be careful!
Henry Happened (author) in reply to regularityaudiolabsSep 19, 2011. 2:52 PM
Thanks for the comment! I've worn it several times and had no problems!
Treknology says: Sep 19, 2011. 6:56 AM
That looks way cool. I have a strange passion for Stainless Steel...
paqrat says: Sep 18, 2011. 10:01 PM
Very nice looking but I think I'd also be concerned with using the screw assembly part. I can think of a couple of other things to thread through the holes, another color strip of metal, metal wire in different colors, leather strips, fishing line strung with beads (on outside of the bracelet).
thebeatonpath says: Sep 18, 2011. 11:48 AM
Sweet! Headed to Lowes shortly!
KateGladstone says: Sep 18, 2011. 7:18 AM
Does it have to be ribbon? Why not those woven-plastic straps that are often put around appliances or other packages readied for shipping? After all, you can get those ribbon-like items for free, and they are easier than ribbon to thread through holes and to clean when needed.
mslaynie in reply to KateGladstoneSep 18, 2011. 10:06 AM
Actually, you can experiment with anything you like! Consider instructibles your first step for inspiration... you can take any idea and expand it, combine it with others, or just run with it to do your own thing. There really aren't any rules!
lironess says: Sep 18, 2011. 8:34 AM
I gave my ex a small hose clamp for a ring....he wore it once and then said it was too scratchy to wear so if you want to wear one get out a file or some fine sandpaper and feel around for any scratchy parts and smooth them down...
clintonmc says: Sep 13, 2011. 9:49 AM
Very nice! I also enjoy trawling DIY stores to find inspiration and new alternative uses for things, and this is a great, elegant example.
porcupinemamma in reply to clintonmcSep 13, 2011. 9:11 PM
That's one of my favourite things to do too!
porcupinemamma says: Sep 13, 2011. 9:10 PM
Beauty!
velorna says: Sep 12, 2011. 11:09 AM
Way Cool! You have just given me inspiration for my birthday outfit stay tuned....
enatti says: Sep 12, 2011. 10:51 AM
Like!!!!
eross-1 says: Sep 12, 2011. 10:47 AM
so cool! also I'd paint the edge of the ribbon with clear nail polish so they don't fray:)
scoochmaroo says: Sep 12, 2011. 9:39 AM
FANTASTIC! I love this.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
