Introduction: DIY Homemade Steering Wheel USB PC With Viberation
Hello guys this is my Homemade Steering wheel (Mark 5) .....this wheel is really awesome..it has vibration features as well .......it has a sequential shifter,analog switch for nitrous and handbrake and obviously has acceleration/brake pedals.....quite easy to make......link to youtube video of this wheel's gameplay:
https://www.youtube.com/watch?v=TECpZM4nTCU
Step 1: Things U Need
  1. a potentiometer (100k)
2.a cheap analog gamepad
3.basic stuff like glue
4.aluminum foil
5.a steering wheel(or something that looks like one,or maybe a plastic disk- use ur creativity guys!! ;) )
Step 2: Basic Structure of Wheel
  1. take a box..
2.get a rod like structure(can be a pvc pipe or something..or maybe a hollow plastic rod) through it and glue it to the potentiometer inside the box.
3.assemble as shown in figure..
4.the potentiometer can be fixed and glued to a thermocol which is glued inside the box......whatever u do--but the potentiometer should be fixed and rigidly attached..
5.solder wires out of the potentiometers connecting ends..
Step 3: Making Gear
Basic Structure:assemble as shown in figure..
wire the gear as shown in figure and u will get 3 wire ending-one main,and other secondary(as shown in figure)
Step 4: Making Pedals
Basic Structure:follow the image
Now here u will make acceleration pedals as well as brake pedal...so u will make two of the ones shown in figure...now the important thing is that u will get 4 wire ending-but u have only 3 coming from gamepad..so what u will do is that u will take any two same place wires from both pedals(suppose u take both the nail wires) and u will connect them...now u will have 3 wires..two from different foils from different pedals(secondary wires) and one from both the nails of the pedals(main wire)..
Step 5: Handbrakes/Nitros
take a potentiometer (from another gamepad) as shown in fig and solder any one side....then attach it to wheel and get the wires out of your rod..if u cant find a potentiometer,then make nitrous and handbrakes by same way as gears ..or use switches instead
final look in picture
again here u will get 3 wires..one main(always the middle one) and 2 secondary wires
Step 6: Connections
take your gamepad apart(open it)
when u open it up, u will see a pcb like shown in the figure...
solder the required connections (in the gamepad's pcb) as shown in figure.....also put hot glue on it...(or maybe M-seal)
then melt holes in the gamepad's plastic and get the wires out of it....make sure u have access to the analog button(VERY IMPORTANT)
during the connections,u will always take the main wire and attach it to the main wire(always the middle on)of the pcb and secondary wires to the secondary wires(left or right) of the PCB (gamepad)
once done then close the gamepad back and follow the assembly in the next step
Step 7: Assembling
this is the part where u assemble all the things up to make ur wheel..follow the figures
i attached the vibrator(motor)from the gamepad in thermocol and fixed it to one end of the box...so as to allow vibrations being felt..
as u can see from the figure,i took out the r1-r2 & l1-l2 wires from the holes (that i had melted)of the gamepad...
and most importantly-to switch on to analog mode,i open the box and press the button..
Step 8: DONE!!
done with the making!!now test it...follow the steps
Step 9: Testing and Setting Up Vibration
  1. open start menu and write set up..u will see set up usb game controllers..open it..
then click the gamepad..and open properties
  • rotate wheel and see if the dot is moving as well..(as shown in figure)
  • then test all other peripherals and see if all buttons are hilighted when pedals/gears/handbrakes are used
  • if yes Njoy!!
    VIBRATIONS
    to set up vibrations install ur drivers provided with the gamepad..else find ur drivers on net
    then test the vibrator in the vibration pannels(by clicking 'Both Forces')in vibrator pannel(in set up usb controllers)
  • Step 10: Coustomising
    now you are done with making!!customize your steering wheel with your need and enjoy!!
    link to video of it in action:
