3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Homemade Whiteboard on the cheap!
  • last photo ←
This whiteboard made from household materials works like any other- and you can make it in any shape or size you choose!
Materials:
Cardboard (cardboard with white on one side works best)
1 Ziploc Storage Bag
Pencil
Measuring Tape
Paper Clips
Xacto Knife
Dry Erase Markers
Step 1Cut your Cardboard
Cut your Cardboard
Measure, mark & cut your cardboard.
Mark the dimensions 8.5" x 11" -the size of normal printer paper.
After cutting your cardboard with an Xacto Knife or similar cardboard cutter, if you are using cardboard that's brown on both sides, glue or tape a piece of blank white printer paper to one side of the cardboard.
23 comments
Mar 12, 2012. 2:25 PMjanewalt34 says:
Another whiteboard idea is one that's a wall decal. They're the new thing these days and you can find some good priced ones on www.Incrediline.com . They use a peel and stick method which makes it easy to install and remove. Perfect for kids of any age. Try them out!
Sep 30, 2010. 5:24 AMcraftyv says:
Good idea. I have been using my handy white board for ages and it still works fine. I simply had a huge piece of white paper laminated and vwa-la.
My kitchen glass cleaner, metholated spirits and nail varnish remover all work fine as long as the pens are NOT permanent.
Good Luck.
Jan 20, 2008. 3:25 PMstevenvu2011 says:
Aren't there cans of spray paint that lend the whiteboard property to things it's sprayed on? I may just be exhibiting wishful thinking. Great idea!
Jan 6, 2009. 8:30 AMDerin says:
Are you talking about spray enamel?
Nov 25, 2008. 4:50 PMItsTheHobbs says:
yeah, I've used it before.
Aug 31, 2008. 2:17 PMtigergibb says:
I think I've seen this at home depot or something before...
Mar 6, 2008. 10:38 AMsideways says:
Pretty smart :) If you're too cheap to buy dry-erase markers (like me) use a Sharpie to write on your plastic. Use rubbing alcohol to remove it.
Dec 30, 2008. 2:18 AMDerin says:
Wouldn't that be more expensive in the long run?
Jan 2, 2009. 7:28 AMsideways says:
Not if I already have them.
Jan 2, 2009. 8:57 AMDerin says:
They will eventually run out,and you will have to buy a second substance to erase it.
Dec 29, 2008. 10:03 PMChiana_Rei says:
What about chalk boards, i know they are dusty, but here is nothing quite like that scratch scratch sound for working out ideas, I have a homeade one in my work area with the classic eraser and colored chalks ;)
Aug 27, 2008. 12:49 PMChuck P. says:
Wow thats actually really cool. Great job!
Jun 17, 2008. 6:33 AMGage987 says:
I have a dixon marker and never put it down and found other white boards if you have a little mirror it can act like a whit board and you can doodle on your reflection but erasing it makes smudges so I put liquid glass cleaner in a spray bottle and put that on before I erase
Mar 15, 2008. 11:34 AMruraldog says:
I really love this idea. I'm an elective, Junior High journalism teacher. My students tend to go nuts on the main white board - love message central, etc. I am going to put this instructable out, credited, in our next newsletter (if approved by the author here). The kids will DEFINITELY try it and it will keep my classroom board "cleaner." :-)
Dec 31, 2007. 12:48 PMteh darkcloud says:
Wow, this is a lot easier than what I was doing. :P I was sticking clear packing tape on paper. It was taking a while (because it was 2 pieces of paper wide by 2 pieces high) so decided to take a "break" and go back to it later. Then I got lazy... it's been months since I've even seen the thing. >.< Shoving cardboard into a ziploc bag seems a lot better!
Dec 10, 2007. 11:23 AMzachninme says:
This... this is... brilliant!
Dec 12, 2007. 6:12 PMFenwick says:
Great thinking eLeet. Never would have thought of this. I know that some small whiteboards go for upwards of 10 bucks, this is a good solution.
Oct 17, 2009. 11:46 PMEleriK says:
I'm just wondering why you wouldn't cut the bag into a sheet and then put something like double sided tape on the reverse side, then stretch the bag out over that until it's taut, then reinforce the bond on the reverse side with something like duct tape.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:eLeet
I love looking at everything in new ways- whether it's a problem that needs an innovative solution, or a philosophy about life that I come up with. I love tinkering with stuff, and doing things that d...
more »
