3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Hookah Hose
DIY Hookah Hose
This is a super easy mod for a Hookah Hose.
If your not new to Hookah, you know your hoses will give out, rust, and need replacing. You can pop another $10-$24 for a hose, or you can salvage parts from your hose to make a new one. Your new hose will be 100% washable, plus you'll have the ability to watch the smoke get drawn thru the hose (kool side effect).
Step 1What you need
What you need
First you need some supplies:
A length of tubing (more on the tubing later: step 3)
Razor blade
Microwave safe glass
Water
End tips from old Hookah hose
20 comments
May 11, 2008. 2:21 PMYerboogieman says:
you should have an Instructable for making a single hose hole to a dual hose hole, so two people at a time
May 31, 2011. 10:26 AMgadget613 says:
i will in time, i just need to get some orders done for Biosmoke then ill do it. im new to this site so ill get to kno it first and then ill put one up to turn a single into a multiple hose
May 26, 2011. 4:56 PMgadget613 says:
or u can do what i did and turned a 4 hose hookah into a 8 hose
Apr 26, 2009. 7:21 PMjongscx says:
It's not as simple as a splitter... more like a splitter and a one-way valve for each hose, so you don't end up sucking air in from the other hose...
May 20, 2011. 10:40 AMgadget613 says:
Ive done this before, but i stepped it up a notch, i put lights in it. i didnt stop there, i made a gas mask for hookah, the ppl here loved it so much i started a business called Biosmoke custom hookah gear. but i am running out of customers here because pretty much everyone has one now that smokes hookah. heres a pic tell me what u think
Jul 25, 2008. 10:35 AMstncilr says:
you should watch out cause the heat of the smoke or whatveer could cause plastic fumes to release into your sweet sweet lungs.
Jun 11, 2009. 2:42 AMXkidXhavocX says:
the smoke goes through a water bubbler to cool the smoke down for a softer hit... so no plastic fumes... maybe just a little plastic taste for the first few uses....
Nov 8, 2008. 12:54 PMlgcalex says:
the 'smoke' from the hooka is room temperature by the time it hits the hose. Its more of a vaporizer system anyways. The charcoal heats the molasses tobacco and causes it to vaporize. If it gets hot enough to burn the tobacco, the taste is terrible and you move the coal or break it in half.
Jun 18, 2008. 7:21 PMjoemonkey says:
what is a hookah hose, like a big cigg?
Jun 25, 2008. 12:57 PMThe Mollusk says:
A hooka is kinda like a bong with hoses.
Jun 8, 2008. 5:09 PMz06killa says:
if you've tried more then one hose for extended periods of time, you'll know that the two ingredients that make you miss the full flavor are the hose and the type of charcoal a good hose has a short break in period, this one will NEVER break in the best ones are the ones made with some cardboard in their mix, but you can't wash them
May 1, 2008. 12:09 AMlostalien says:
Awesome!!! The rexine hoses always caused problems after a few months of use... i'll try doin this... should rock!!!!
Mar 26, 2008. 2:46 PMarmourkris says:
I've dis the same thing to make a new hose for my hookah a few years ago, only i used surgical tubing
Nov 3, 2007. 8:49 PMSelf-Serving Martyr says:
What could I use for end tips if I do not already own a hookah? I'm thinking of making one for a friend.
Dec 3, 2007. 7:45 PMjongscx says:
...I'd think just about anything you can suck through... then build up a handle with duct tape?
Nov 11, 2007. 10:14 PMhalogod007 says:
lol for the people who are looking to buy their own hoses, i get mine at http://www.blowos.com
Jun 26, 2007. 2:48 PMTetranitrate says:
Hmm, I have an old Hookah in the closet with very dirty hoses and mouthpieces. I might try this out, Thanks.
Jun 24, 2007. 4:52 AMRectifier says:
"food-safe" hose can still be gross and plastickey. The best hose I've seen was beer line hose from a homebrew shop. It's around the same price as hardware store hose, too.
Jun 20, 2007. 1:25 PMtrebuchet03 says:
Please add an image to your introduction step. I'm unpublishing this, for now -- but please feel free to republish once this correction has been made. Once it is republished, with corrections, I will delete this note.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:sammniamii
I'm weird and wonderous... ok, atleast the weird part is true :)
