3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Hot Air Soldering Iron
Step 2Take Soldering Iron Apart
This is what you get when you take a soldering iron apart: a handle, a simple resistive heater, and a sheating to protect the heater (or protect other things from it). The tip has been removed in this picture. The nut shown at the far right side of this picture holds the soldering iron tip in by a small lip.
Luckily, the entire thing is hollow! Every single part of it - including the heating element. It's almost as if this thing were made to be modified.
3 comments
Feb 23, 2011. 8:25 PMBigfish_102390 says:
I have a soldering iron I'm curious as to how u get the sheathing loose without hurting the iron because it is riveted to the handle.
Jan 3, 2010. 8:23 PMmicoh2010 says:
 and one more thing i dont have nor can buy in my place a soldering iron like yours that have a nut on the end only a screw from the end side it come. So what should i do to make a nozzel?
Feb 17, 2010. 9:46 PMhore says:
you dont have to follow everything100%. just make sure hott air go through.
Jan 3, 2010. 8:18 PMmicoh2010 says:
 Hey bro can you give more detail? like for the tube were will it pass throug aside from the element? because as i see on the photo there is a steel pipe like that i think is the enclosure for the element do i also insert inside the tube all the way to the other end? its confusing.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:charper
