3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Hot Air Soldering Iron
Step 3Add heat exchanger
Add heat exchanger
In order to effectively heat the air, we have to do something to increase the surface area it passes over. I was hoping to use copper rather than stainless steel for this; but I couldn't find any copper scouring pads. The closest thing available was the "Chore Boy" stainless steel scouring pads. I feel however, that if it were available, copper would be superior. As you can see in the picture, simply stuff a few strands into the end of the heating element. Be careful not to get too much. You should test blow into the end of the heating element and make sure air still flows relatively unobstructed.
Note: Stainless Steel can catch fire... Use copper if at all possible
9 comments
Aug 6, 2008. 8:12 AMcarlitoscr says:
Well, I think you can use a piece of copper solder wick as your heat exchange element. you can either place the piece of solder wick as it is (being careful it doesn't offer too much resistence to the air flow) or you can take your time to separate all the copper threads and then make a small ball with them (be carefull not to compress that ball, it has to be porous). Use the porous copper thread ball as your heat exchange element. Good luck!
Aug 21, 2008. 6:46 PMIan01 says:
These wicks usually contain rosin flux, which could be detrimental. On the other hand, you might get vaporized flux that could help with the desoldering.
Sep 15, 2009. 7:40 AMconny17017 says:
How about using some of the woven copper or aluminum jacketing on coax cables
Nov 27, 2011. 8:31 AMPolymorph says:
The aluminum will corrode quickly in the heat, don't know how much that will affect it. Good idea, though.
Sep 26, 2009. 3:39 PMIan01 says:
The copper would probably work, but I wouldn't use aluminium because its melting point may be too low. That's why it isn't used for model rocket launch stands. Those have steel blast plates.
Oct 22, 2010. 3:55 AMbeehard44 says:
i melted aluminum with the whoosh rocket once
Mar 4, 2011. 8:54 PMtechno guy says:
Can you use steel wool for the heat exchanger?
Nov 21, 2011. 1:51 PMMirage_662 says:
Thermal lance anyone?
Oct 11, 2009. 6:58 PMronmaggi says:
 Boating goods stores sell bronze wool, would that work well for the heat exchanger?
Aug 13, 2009. 4:51 PMJayWDavis says:
Thanks for sharing your design. Another source for stranded copper wires is regular old phone cord. The easiest way to remove the insulation (once the outter cover is removed) is to sever it with the soldering iron and it slides right off
Jan 26, 2009. 1:05 AMm1kta says:
I meant RG316 but you could also use RG213.
Jan 26, 2009. 12:56 AMm1kta says:
The copper braid from RG58/RG312 would be as good if not better than the scouring pad stuff. And doesn't contain the solder flux desoldering braid does... you could always just warm/heat the desolder braid until it just smokes with a blow torch and once cool wash it with water/liquid detergent if realled needed.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:charper
