Step 9The nozzle
OVERVIEW: I marked on the handle of the plastic cover where there would be a hollow space for me to drill a hole and insert some tubing once the unit was together. Air would later be pumped through this tubing. This was important to get right, so I used calipers and a few marks to get the right length. The next problem I encountered was to get a nozzle for the tip. I reversed the inside shaft previously used to hold the heating element and dremelled the flange and it fit perfectly. I now have a nozzle!! Next step was to use a nozzle from my aquarium that would fit into the handle and fit also the plastic tube that will have air flowing through it. I drilled a hole where "X" marked the spot, being careful I didn't have too much pressure on the drill. I would have done this with the gutz removed but felt I could get away with not perforating the innards if I was careful. This arrangement worked, but is only temporary as I want to see if the concept worked. I will later add some mechanical retention here by using a screw nipple or something. With the solder iron nearly fully together, I needed to tackle the issue of getting air into the thing. I had no air pump used for an aquarium. I have an aquarium, but don't use them, they are so inefficient. What I do have is the bad ass air blowers from the hot air guns I got from the dump. These babies are huge compared to the small tube I have to run into the solder iron.
Add Comment
