Make Variable DC Lab Bench Power Supply That Fits in Your Pocket !
13,624
247
11
Published
Introduction: Make Variable DC Lab Bench Power Supply That Fits in Your Pocket !
About: Ideas Into Reality !
Let's Make Ultra Small Sized Dc Variable Lab Bench Power Supply Using Buck Boost Converter Module And 1A Lithium ion Battery charging Board From ebay.
" Its So Small That You Can Carry It Anywhere !"
This Variable Power Supply Is Excellent Starter Electronics Project For Begineers , its Modular So You Can Buy Each Module From ebay at Quiet Cheap Price .
Buy Parts Here
♦ Dc Buck Boost Converter Module (2.26$)
http://www.ebay.com/sch/i.html?_sop=15&_nkw=buck+boost+converter+cc&rt=nc&LH_BIN=1
♦1A Lithium Ion Battery Charging Board (1$)
http://www.ebay.com/sch/i.html?_sop=15&_nkw=tp4056&rt=nc&LH_BIN=1
li-ion Battery Can be reused from your old cellphones For Free !
This Buck Boost Regulator Uses Most Popular Lm 2596 and Xl6009 For Step Up And Step Down Respectively . This Dc-Dc Buck Boost Converter Is Capable of Supplying 1.25 - 35 Volts With 1.5 A Current
The CC (Constant Current ) & CV (Constant Voltage) Ability Makes This Chip Perfect For Small portable Power Supply . The Great Thing About This Diy Project is Its Cheap Cost And Portability it gives you freedom to test any electronics at remote locations.
Enjoy The Step By Step Tutorial Procedure To Make This PoWer Supply !
Find me on social Networks
# Facebook
https://www.facebook.com/pages/Kedar-Nimbalkar/547219125414748?__nodl
# Twitter
https://twitter.com/kedar264
Step 1: Watch Video Tutorial !
https://youtu.be/hzYS6GtqRs0
Step 2: Get Parts
Buy Parts Here
Step 3: Connect Battery Charger
1. Clean the battery terminals with cleaning solution like isopropenol alcohol & then apply flux to make soldering easier.
2. Apply sufficient amount of soldering metal on battery leads.
3. Strip ends of wires.
4. Dip wires in flux and tin them.
5. Solder TP 4056 li ion Battery charging board to battery , use double sided tape to stick it on to battery.
Step 4: Connect Buck Boost Converter
1. Carefully Solder Input & Output terminals from Buck Boost converter With appropriate Polarities.
2. Connect a Switch to control the power supply.
we're almost done ...
Step 5: Almost Ready to Go..
1. Additionally you can use panel voltmeter to display Voltage and also connect led at the output.
2. Connect a diode at the output in reverse Polarities to reduce back emf from inductive loads.
  • Casting Contest
    Casting Contest
  • Oil Contest
    Oil Contest
  • Planter Challenge
    Planter Challenge
11 Comments
I really need some help right now..
that kind of power board is not available in my country... which of these boards can i use?
this one?
https://www.google.com.ph/search?q=ltc3780+philippines&prmd=ivn&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjtytGn7pPTAhWGJZQKHdxuCLI4FBD8BQgFKAE&biw=360&bih=512#tbm=isch&q=150w+boost+converter&imgrc=BylQMLurUM29fM:
or this one?
https://www.google.com.ph/search?biw=360&bih=290&tbm=isch&sa=1&ei=XFLoWNS9J4Hi0gTy96y4Cw&q=5-30v+boost+converter&oq=5-30v+boost+converter&gs_l=mobile-gws-img.3...190944.202527.0.202889.27.23.4.0.0.0.224.2506.11j9j2.22.0....0...1c.1j4.64.mobile-gws-img..1.14.1561.3..0j35i39k1j0i5i30k1j0i8i30k1j0i24k1j30i10k1.6jfUJrOvVB0#imgrc=v0TDbSC6kJbNBM:
Thanks..
whether I can use DC to DC Buck converter
Can someone sent my a direct link for the Buck Boost Converter. I can just find some similar.
great idea! I'm going to try this one.
I'm going to try this to power a laser diode. Will it work if I connect to driver first?
Why not? It should work if you connect the right voltage...
