DIY - How to Make Slime With Toothpaste
50,882
39
42
Posted
Introduction: DIY - How to Make Slime With Toothpaste
Tutorial How To Make Slime using Toothpaste and Glue
Step 1: Step 1: Materials
Materials:
  • Elmer's white glue
  • Crest Gel toothpaste
  • 1 bowl (for mixing)
  • 1 spoon (to mix)
Step 2: Step 2: Make Slime
Start by adding Gel toothpaste into the bowl
Add some white glue and mix them until it get sticky
Step 3: Step 3: Mix Until Slime Doesn't Stick
Touch the slime with your finger
If stick to finger add little more glue and mix
Repeat until slime doesn't stick to the finger
Now u have a slime to play it
Step 4: Step 4: Store Your Slime
Place slime into Zip Lock bag to keep it from drying out
Thank you for viewing my tutorial. :)
Instagram https://www.instagram.com/riceyummy
Subscribe to my Youtube channel https://www.instagram.com/riceyummy
  • Microcontroller Contest
  • Science of Cooking
    Science of Cooking
  • Pocket-Sized Contest
2 Questions
How do you make toothpaste slime with glue I don’t have glue
Does it have to be that type of toothpaste?
22 Comments
but mines didn't work it was still sticky then I added a little more glue
But did not work:( ☹️
The toothpaste is basically the activator so u would need to add more toothpaste!
can u make two slime for me please
do you have to use colgate or can you use aquafresh
That's good that people go out of their way to find other ways to make slime besides borax and glue, contact solution and glue, etc. Does it work with only gel toothpaste? Thanks!~
I haven't tried yet but it seems to work. I ran out of glue...:)
But I'm trying gel elmers glue bottle, because my toothepaste is not gel
Yes! This is the easiest slime recipe, and I have both ingredients!
It's easy to make and easy to get the ingredients!
(If this helps, you can use any toothpaste or any PVA glue)
As I'm in the UK, I don't think there is elmers glue here and in other countries as well, so just use any old PVA glue, it should work.
