DIY How to Make a Ghillie Suit
Published
Introduction: DIY How to Make a Ghillie Suit
About: Become the Ultimate DIY Hunter & Fisherman!
Learn how to make your own ghillie suit cheap and easy using 3D fabric. A great DIY project to make an inexpensive 3D camo suit under $20!
We show you how to make this ghillie suit in 3 basic steps:
  1. Measure, cut, and tape with camo form to create the 3D camo pants.
  2. Use the 3D camo fabric left over from the pants to make the ghillie suit top by cutting a hole in the middle for the head and creating sleeves with the camo form tape.
  3. Fray the bottom of the pants to eliminate straight lines. Do the same to the top of your new homemade ghillie suit.
These steps provided above is just the simplest way in explaining how to make the cheapest and easiest ghillie suit around! The video will show you a lot more of details to make sure your DIY ghillie suit is the best it can be.
Ghillie suits work great for all kinds of hunting whether it’s deer, turkey, duck, hog, or any other kind of game. Make sure to buy the camo fabric best for your use and most similar to your surroundings for the most successful results. If you find this video helpful, leave a comment and share with your friends. Thanks for watching!
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    2 Comments
    Find burlap that has had camo printed on it , make your suit with it . Much cooler , and I believe that its letting some light through the material helps to keep you unseen .
    Good idea, thanks for the tip, we'll try that next time! Makes sense, maybe the holes would make you less 'solid' and blend in a bit more.
