3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Human Powered Wooden Hydrofoil - The "Hydrothopter"
Step 7Canard Assembly
Canard Assembly
The CANARD WING is maple, 25" long, 2.4" chord, .28" thick. See step 4 for foil section. Any 12% or 13% thick section that's strong enough would be fine.
It's bolted up into the STRUT with the same bolt-to-nut-in-cross-hole method as the main wing uses.
The STRUT is .72" thick plywood, 27.5" in the longest dimension. The vertical part has 3.9" chord and is shaped into a foil similar to the UPRIGHTS. It is 11" tall and is shaped to mate with the top of the CANARD WING.
The SURFACE FEELER is a 6" disk of plywood. When the canard wing is flat on the ground, it is 3" off the ground, inclined upward at a 5 degree angle.
1 comment
Feb 8, 2012. 11:23 AMTruthHunter says:
When I look at the Canard, I don't see the dimension between the pivot
point and the leading edge of the canard wing. Or should it be the ratio to the Feeler arm and the Canard foil? It looks like its about 3"
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1250
Author:TimAnderson
Tim Anderson is the author of the "Heirloom Technology" column in Make Magazine. He is co-founder of www.zcorp.com, manufacturers of "3D Printer" output devices. His detailed drawings of traditional ...
more »
