DIY IR (Infrared) Illuminator - Night Viewing With Your Camera
 by john.kerr
One question we get asked a lot is about building an IR Illuminator. An IR Illuminator allows a camera to see in total darkness. This can be useful for security applications or maybe you want to watch the night activities of the local wildlife.
The IR Illuminator is based around our LED SpotLight PCB which holds a total of 24 LEDs on a circular PCB. The board is equipped with 24 special IR LEDs which do all of the work, along with 8 current limiting resistors. This project is very simple to build up, and can be fully assembled by a novice builder in about 30 minutes.
On our website at www.pcboard.ca, we produce a number of unique and exclusive LED products and accessories including solutions for mounting LEDs.
When you build your IR Illuminator, you need to decide what frequency of LEDs to install on the board. There are two common frequencies available, one at 940nm and the other at 850nm. The most commonly used frequency with black and white CCD cameras is the 940nm model.
850nm LEDs produce a very slight red glow when operating, which is visible to the human eye. 940nm models produce no visible light to the eye.
We carry both frequencies of the IR LEDs, see our LED Page and look for model IC601-02 for 850nm and IC601-03 for the 940nm models.
When complete, the system will produce a circular spotlight on the wall about 10-foot (3 meters) in diameter at a distance of 10-feet (3 meters) which is more than ample to light up a front door waiting area or a location outside.
Step 1: Getting The Parts Together
Your first step is to identify and collect the parts necessary to build the system. We will be using our LED SpotLight PCB, along with 24 of our Ultra-Bright IR LEDs and 8 resistors. Shown to the right are all the parts that are required. Once fully assembled, power to the circuit is needed and we have setup this one to run on 12v DC at about 160mA (0.160A). To run at other voltages, you must select the correct value of dropping resistor (of which there are eight) - we have even simplified this process with our online Dropping Resistor Calculator. For this build, we are using 390ohm one-quarter watt resistors.
Once you have all the parts, the first step is to become familiar with the PCB. It is setup with 24 LEDs in total, 16 around the outside and another 8 on the inside (all the LEDs are labeled D1 to D24). The resistors will go on the board at position R1 to R8 which are located between the inner and outer rows of LEDs. Finally, power is applied to the board just below D24 where you will see the Positive and Negative solder pads. In the very center of the PCB is a single hole. This hole can be enlarged to be used for mounting or even further to fit around a camera lens.
Aphexi says: Dec 19, 2012. 8:48 AM
"It is setup with 24 LEDs in total, 18 around the outside and another 8 on the inside (all the LEDs are labeled D1 to D24)."
Ehm...LOL... 18 + 8 = 26 ;-)
This is just a hidden advert. If you show us the schematics, you will be given much more credit.
This way, it just looks like massive SPAM!
Rene Artois says: Aug 30, 2012. 2:41 AM
Can you just simply attach schematics, so people here make own DIY project?
How these LEDs are grouped, powered etc.?
Otherwise it looks like advert.
mitchc says: Aug 5, 2012. 9:27 AM
Why are people complaining about $2.00 to etch and drill their own PCBs to save what ? Isn't your time worth anything? The only time I make my own PCBs is for my own designs as a prototype. After that, I'd much rather send it to a fabricator to make a dozen or more Professional boards with soldermask and silkscreen can't be beat. Just my opinion, but ....
BrunoPKBR says: Feb 26, 2011. 10:10 AM
Cool! I made it in my webcam But, 1 infrared led these tv controler.
(I'm sorry my english, i'm from brazil)
Soon, i will do a tutorial... See you!
Thanks!
HarveyH44 says: Dec 9, 2009. 5:13 PM
Where can I find the PCB artwork?  I prefer to etch and drill my own boards.  I've done a couple with perfboard, but always wanted a round design.  Guess you wouldn't sell many kits, if people made their own...
john.kerr (author) in reply to HarveyH44Dec 9, 2009. 6:27 PM
Don't have the artwork available separately sorry. The documentation/schematic is available from http://www.pcboard.ca/kits/led_spotlight/
john
dogsop in reply to john.kerrDec 10, 2009. 7:48 PM
Without providing the way for people to make their own boards this whole instructable seems to be nothing more than an ad for your boards.
silencekilla in reply to dogsopAug 25, 2010. 7:41 PM
I agree and they expect us to pay $4.00 USD for a bare board with no components. Thats rediculous i might pay $2.00 for it but definatly not $4. Thats just a complete rip off.
cbmuir in reply to silencekillaSep 29, 2010. 11:20 AM
Really? You're complaining about a $4.00 circuit board? About a delta of $2.00 over the $2 you'd be "willing to pay?" This sort of negativity could have the consequence of discouraging people from publishing their projects, I think. I don't think that there's some sort of "fat cat," getting rich on the sale of $4.00 circular boards with solder mask and silkscreen.
john.kerr (author) in reply to dogsopDec 11, 2009. 7:07 AM
There were a few requests for the PCB layout, so I now have a dedicated page to assist in doing up your own board.
Have a look at: www.pcboard.ca/kits/led_spotlight/diy.html
lemonie says: Dec 9, 2009. 4:02 PM
You appear to have used the same image 5 times, but we still don't see the finished item. Can you get the use of a camera?
L
john.kerr (author) in reply to lemonieDec 9, 2009. 4:21 PM
You should see a slightly different image in each step as the build happens - there are separate files uploaded and I do see a slightly different image on each step. Give it another try.
lemonie in reply to john.kerrDec 10, 2009. 12:22 AM
Oh yes, it's the 90 degree angle makes it hard - finished item pic, in a case / on a mount?
L
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
