3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY IR (Infrared) Illuminator - Night Viewing With Your Camera
One question we get asked a lot is about building an IR Illuminator. An IR Illuminator allows a camera to see in total darkness. This can be useful for security applications or maybe you want to watch the night activities of the local wildlife.
The IR Illuminator is based around our LED SpotLight PCB which holds a total of 24 LEDs on a circular PCB. The board is equipped with 24 special IR LEDs which do all of the work, along with 8 current limiting resistors. This project is very simple to build up, and can be fully assembled by a novice builder in about 30 minutes.
On our website at www.pcboard.ca, we produce a number of unique and exclusive LED products and accessories including solutions for mounting LEDs.
When you build your IR Illuminator, you need to decide what frequency of LEDs to install on the board. There are two common frequencies available, one at 940nm and the other at 850nm. The most commonly used frequency with black and white CCD cameras is the 940nm model.
850nm LEDs produce a very slight red glow when operating, which is visible to the human eye. 940nm models produce no visible light to the eye.
We carry both frequencies of the IR LEDs, see our LED Page and look for model IC601-02 for 850nm and IC601-03 for the 940nm models.
When complete, the system will produce a circular spotlight on the wall about 10-foot (3 meters) in diameter at a distance of 10-feet (3 meters) which is more than ample to light up a front door waiting area or a location outside.
Step 1Getting The Parts Together
Your first step is to identify and collect the parts necessary to build the system. We will be using our LED SpotLight PCB, along with 24 of our Ultra-Bright IR LEDs and 8 resistors. Shown to the right are all the parts that are required. Once fully assembled, power to the circuit is needed and we have setup this one to run on 12v DC at about 160mA (0.160A). To run at other voltages, you must select the correct value of dropping resistor (of which there are eight) - we have even simplified this process with our online Dropping Resistor Calculator. For this build, we are using 390ohm one-quarter watt resistors.
Once you have all the parts, the first step is to become familiar with the PCB. It is setup with 24 LEDs in total, 18 around the outside and another 8 on the inside (all the LEDs are labeled D1 to D24). The resistors will go on the board at position R1 to R8 which are located between the inner and outer rows of LEDs. Finally, power is applied to the board just below D24 where you will see the Positive and Negative solder pads. In the very center of the PCB is a single hole. This hole can be enlarged to be used for mounting or even further to fit around a camera lens.
10 comments
Feb 26, 2011. 10:10 AMBrunoPKBR says:
Cool! I made it in my webcam But, 1 infrared led these tv controler.
(I'm sorry my english, i'm from brazil)
Soon, i will do a tutorial... See you!
Thanks!
Dec 9, 2009. 5:13 PMHarveyH44 says:
Where can I find the PCB artwork?  I prefer to etch and drill my own boards.  I've done a couple with perfboard, but always wanted a round design.  Guess you wouldn't sell many kits, if people made their own...
Dec 10, 2009. 7:48 PMdogsop says:
Without providing the way for people to make their own boards this whole instructable seems to be nothing more than an ad for your boards.
Aug 25, 2010. 7:41 PMsilencekilla says:
I agree and they expect us to pay $4.00 USD for a bare board with no components. Thats rediculous i might pay $2.00 for it but definatly not $4. Thats just a complete rip off.
Sep 29, 2010. 11:20 AMcbmuir says:
Really? You're complaining about a $4.00 circuit board? About a delta of $2.00 over the $2 you'd be "willing to pay?" This sort of negativity could have the consequence of discouraging people from publishing their projects, I think. I don't think that there's some sort of "fat cat," getting rich on the sale of $4.00 circular boards with solder mask and silkscreen.
Dec 9, 2009. 4:02 PMlemonie says:
You appear to have used the same image 5 times, but we still don't see the finished item. Can you get the use of a camera?
L
Dec 10, 2009. 12:22 AMlemonie says:
Oh yes, it's the 90 degree angle makes it hard - finished item pic, in a case / on a mount?
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:john.kerr(PCBoard.ca)
