DIY IR Proximity Sensor
1,667
20
Published
Introduction: DIY IR Proximity Sensor
About: Electrical engineer by profession
Hello guys
In this post I will show how to make a simple IR proximity sensor
IR Proximity have one IR LED & one Photodiode
LM358 IC is used in this project
Basically IR LED will transmitte Infrared light when this light fall on reflecting surface (white surface) it will fall back on Photodiode so in proportion of IR light fall on Photodiode the internal resistance of photodiode change
LM358 get input from this photodiode and gives output
To complete this project I ordered Electronics components from WWW.LCSC.COM
LCSC.COM is the place to buy electronics components for your projects, so consider to visit LCSC.COM for you future electronics component requirement.
$4 OFF in first parts order - www.lcsc.com
Step 1: VIDEO
Step 2: Component Required
Step 3: CIRCUIT DRAWING
To figure out which terminal is anode and which terminal is cathode
reffer image.
The LED diode bigger leg is Anode(+) and shorter leg is cathode(-)
IR LED anode is connected with 5V DC and cathode is connected with 200 ohm resistor and GND is connected to the other end of resistor
Cathode of Photodiode is connected with 5V DC and Anode is connected with PIN 3 of LM358 IC & 10K OHm resistor, GND is connected the other end of resistor
50K OHM potentiometer two adjecent legs connected with 5V & GND and middle led is connected with PIN 2 of LM358 IC
5V connected with PIN 8 of LM358 IC
GND is connected with PIN 4 LM358 IC
A output load (LED) is connected with PIN 1 with 330 OHM resistor in series.
So IR LED will transmitte Infrared light when this light fall on reflecting surface (white surface) it will fall back on Photodiode so in proportion of IR light fall on Photodiode the internal resistance of photodiode change
LM358 get input from this photodiode at PIN 3 and compare with threshold signal coming from potentiometer at PIN 2 and glow the LED
Potentiometer is used to adjust the sensing range of sensor
    • Oil Contest
      Oil Contest
    • Planter Challenge
      Planter Challenge
    • Woodworking Contest
      Woodworking Contest
    2 Comments
    How can we delay it to turn it off ???
    There is an IC that has this feature??
    really nice, could you please take a photo of your calculations ?
    with the hysteresis comparator, it would be nice to find the distance according to the value of the potentiometer
