DIY Industrial Black Pipe Lamp With Touch Switch
Published
Introduction: DIY Industrial Black Pipe Lamp With Touch Switch
About: There is no greater harm than that of time wasted - Michelangelo Buonarroti
In this instructable you can see how to make industrial pipe lamp. You can change the design and make your own or you can replicate the one I made. The lamp is made with black pipe and edison bulb for cool industial look. The project can be built with minimal tools.
Step 1: Materials
Black pipe and fittings
Bulb Socket
Edison Bulb
Electric Wires
Superglue
Black matte paint
220v Touch Switch
Copper wire
Few years ago I made a black pipe hanger for a DIY contest
Few days ago I decided to make a lamp that will look like it
I also used black pipe to build the lamp
You can easy change the design and make your own.
It is a fast and easy to build project and minimal tools are needed
Step 2: Production
I used rubber coating wire for more safety
I wrapped the ground wire around the bulb socket to make contact with the lamp body
Try not to turn the wire with the pipe parts when connecting them
Make a hole under the lamp for the electric wires
I added a touch on/off switch from aliexpress on the wire, the touch switch has 4 wires, one connected to the lamp metal body.
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    I couldn't help but notice that the pressure gauge on your lamp is in just about the right place for a clock!
    2 Comments
    a 220v touch switch sounds a bit more dangerous in my head than it probably is :)
    It is not dangerous but if you wish you can use normal on/off switch
