3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Infrared Sensor Module
Have you ever wanted to make a line following robot but the infrared sensors were too expensive for you? Do you want to upgrade the robot in my other instructable?
Well this instructable comes in two stages, Stage 1 is the prototyping stage, where you build the circuit on the bread board and debug it for design flaws.
Stage 2 is fabrication where I’ll teach you how to create a strip board product that you can plug straight into your robot.
The good thing about this tutorial is you’re able to do many things with these sensors.
Also, if you’re from the UK and have a maplin store near you, you’ll be able to get some IR transmitter and receivers for 99p (They’re side facing LED/phototransistors, so you can have a low-profile sensor module), More on this at the end of the instructable.
1x Arduino
1x Bread board
1x Strip board
1x Wire reel, black
1x Wire reel, red
1x Wire reel, green
2x Infrared LED (Maplin/Sparkfun)
2x Phototransistor (Maplin/Sparkfun)
2x Red 5mm LED (Maplin/Sparkfun)
2x 1k Ohm resistor
2x 220 Ohm resistor
Wire cutters
Wire strippers
Helping Hands
Heat shrink tube (Not used)
Heat source (Not used)
Soldering iron
Solder
Step 1Let's Get Started
Let\
You want to take your bread board and your infra red LED’s and photo transistors and place them side by side (1 hole apart) in the bread board, repeat for the other infra red pair.
Now let’s start wiring up the infrared LED’s first, place a 220 Ohm resister in the same row as the IR LED cathode then wire it to ground, and make sure to wire both. Next you need to wire up both of the IR LED anodes to the power rail.
15 comments
Nov 20, 2011. 6:08 PMsteveoondyou says:
sweet sweet, I like the line idea for drawing a path. have to try it on an rc car next, or a lawnmower.
Nov 17, 2011. 10:42 PMEax5 says:
Hey, Great instructable exactly what I was looking for.
I am trying to build my own line following robot. I would like to build my own line detector.
I am pretty sure that I can make lets say 6 of these in a row. But I am wondering if they will be interfering with each other?
Nov 18, 2011. 7:31 AMEax5 says:
Cool, how are you detecting the line? Did you simply buy an ir line detection kit?
Nov 14, 2011. 3:19 PMcompsfreak17 says:
Can you please provide a schematic?
I'm having trouble understanding this and already burnt out a detector.
Sep 26, 2011. 9:26 AMDylan Richards says:
im having trouble making it it starts to spark
Oct 30, 2011. 6:42 AMDylan Richards says:
maybe
Sep 26, 2011. 9:07 PMKrzys26 says:
Can I use this circuit and the program, run by Ziolog microcontroller or it has to be exact arduino controller, reason for this I have to design module for my capstone project making the robot that my group is desiging fallow the tape as well, it will be security system looking for motion around with camera activated after it finds it , using Zilog microprocessor, I dont know if code will be simillar or not, if so, modyfing code would be hard with zilog?
Chris
Sep 25, 2011. 7:57 AMimakethings says:
can u use it to measure distance?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
25
Author:Dominion-Network(Dominion-Network)
I've always taken stuff apart, almost always put it back together... I enjoy tinkering around with pretty much anything.
