This tutorial is for creating the Infrared transmitter only.
Can be used with iPhone App DSLR.BOT. http://dslrbot.com
Used for controlling Canon EOS, Nikon, Penta and Sony Cameras.
The way this transmitter works is it sends infrared on and off signals from the audio playback coming from your headphone jack. Having saved an audio file with the correct on and off timings, you can play back this audio track through your portable music player and trigger infrared devices.
This transmitter works better with a WAV audio playback, however this has been successfully tested as an MP3 audio track. The WAV track generally produces a clearer signal as they can playback a 38 KHz modulation (Infrared frequency rate), by dividing the frequency between the two stereo channels. 19 KHz for the left channel and an inverse 19KHz signal for the right.
To better illustrate this the left channel will play an on and off signal ..
0101010101
The right channel will produce the in-between signals for the off time ..
1010101010
Therefor each channel will take turns producing a infrared signal creating a higher frequency rate, equal to that of an infrared remote control.
The Items needed for this DIY project are ..
1) Infrared LEDs 940 nm 2x
2) 3.5 mm stereo headphone minijack
Remove these ads by
Signing UpStep 1Prepare the headphone jack
thanks!
Can I just play back the mp3 and get the desired result? If so,
What should the audio file sample rate and bit depth settings be?
Do there need to be any resistors, capacitors, external power added to the LEDs?
I've testing the transmitting LEDs and I can see the signal on a camera but when aimed right at the tv, nothing happens. Any thoughts? Many thanks.
i have done all the Things you shown but it dont work. I have a Canon 600D. What is wrong??? You say that sometimes problems in Europe. Why??? What ca i do?
thanks!
Is the length of the cord a matter?
Also, what is it that you guys said about a resistor? how many ohms?
Also, I've seen the same setup elsewhere on the web with a minor difference, there's a 10ohm resistor added. Is that necessary? Here's the source http://img212.imageshack.us/img212/8740/icouch2mg1.png
Take the resister out of that diagram, and you have exactly what this instructable is detailing.
A typical infrared diode has a drop of 1.3 volts across it. Based on what I can find, the iPhone should be able to run up to 3.5volts peak to peak -- depending on the audio signal, that means it could do up to 7 volts -- and the internal resistance of the wires and diode will have to take up the slack from the 1.3 volt drop. i.e. 7-1.3 = 5.7 volts to drop.
I don't know if 10 ohms is the right value, and I don't know what kind of current limiting capabilities are built into the iPhone audio output, but I would think that some kind of resistor would be a good idea to protect the audio output of the phone. Any thoughts?
http://www.pentaxforums.com/forums/pentax-dslr-discussion/131633-absurdly-simple-diy-k-x-remote-timer-using-mp3-player.html#post1368821
http://www.dslrbot.com
Can you help me choosing on this page :
http://www.gotronic.fr/catalog/opto/infrarouge.htm
Thanks
