DIY Jaw Chuck for Homemade Wood Metal Mini Mill Lathe
Published
Introduction: DIY Jaw Chuck for Homemade Wood Metal Mini Mill Lathe
These plans are for making a homemade mini metal lathe, great for model making and turning small parts.
More Step by Step Homemade Mini Lathe DIY Wood Milling CNC Router here:
This metal turning lathe has a capacity of up to 80 mm and a maximum distance between centers of about 100 mm. The tools required to build it are a hacksaw, breastdrill, files, clamps, and a few drills, taps and dies. After building the model maker's lathe, the second set of plans will guide you through building the tools and fittings you'll need. The first essential will be the cutting bit. Then you'll learn to make a drill chuck for the tailstock, and later a faceplate.
More Homemade Mini Grinder Belt DIY Sanding Wheel Home Built Grinding Machine here:
    • Microcontroller Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
