loading
Step 2: Washing The Cans
Be sure to clean the whole can by rinsing it with water. You wouldn't want impurities to mix with your alcohol. Mixing impurities with alcohol will degrade the stove's performance. After rinsing it with water dry it with a piece of cloth.
Simple trick for easier sanding-off the paint: <br>BEFORE you wash out the cans, fill them half full of water and freeze them. <br>Now, you have a solid core to back up the can while removing paint -- can even buff it off with a wire pad on a power drill if you want. <br> <br>Let them stand and thaw, pour a drop or two of soap in and shake to foam, wash the cans out and proceed ... <br>
<p>You could fill it almost full, freeze it, and then use a power saw to cut it. Since it's frozen, the saw won't destroy the can.</p>
That's a great idea! I've never thought of that.
Angelo, great job. You are a very talented young man. Best wishes.<br>One thing though, about the hole size, you state &quot;not too big, nor too small&quot;.<br>Might be a good idea as to state what size you made yours. you can always say &quot;It's not too critical, but mine were 1mm or 0.042 in.&quot;. just sayin'. Always a good idea to give exact information when instructing so the person learning will know to expect it to work as good as yours, if not, because they failed to follow instructions. But, hey, still a great instructible and hope to see more from you.
Thanks! Oh yeah about that, I used 0.8mm drill bits for my holes.
Very cool! I wouldn't have thought about using a soda can!
I love the idea! To be quite honest, I am going to go buy the stuff tonight to build it (because this is the only thing I've ever found that you don't have to spend crazy money on and it's worth it to use!)....<br><br>But, how is it a &quot;stove&quot;? What can you &quot;cook&quot; with it? I thought anything to &quot;cook&quot; would crush the little can... so what could you use it for? I am by no means trying to disappoint you or upset you or be rude... I just would like some ideas on what to use it for (I got the idea for a little heating source lamp type thing)...<br><br>Going camping so I will use this when I go.
You can cook foods that takes 30 mins to cook. It boils water for about 5 mins. I tried cooking instant noodles, boiled eggs, scrambled eggs, hotdogs, sausages, fried fries. The amount of alcohol and the size of the stove affects the operating time of the stove. Mine is a bit small so it works for about 30-40 minutes.
I've made 10 different styles - this one is the best by far. The top of the bottle is inverted into the bottom and JB welded. (JB Weld is a cold weld that you mix and apply with a Q-tip to seal and bond the metals together) Holes on the inside and outside. Good clean and well rounded flame. No need for a &quot;Pre-heater&quot; either. there are 3 holes in the bottom - so the outer chamber fills up. light the center and it heats the outer ~ voila. Hardware cloth is the pot holder - make any size / hieght needed.
Thanks for the reply.. I might try this. I am a student and I couldn't see the YT video yesterday (iBoss Filters) but I did yesterday at home and I see the &quot;cage thingy&quot; pictures. That is actually a nice idea/addition. If it is around the can, you can set the small pot on top of the rack thing around it to stabilize it. Thanks for the help!<br><br>I will try to do something like this in the near future...
I did the cage thingy about a year ago. I will try to take pictures of mine, besides that, yours is great.
I made mine very similar to this design. How ever I made a pot holder out of hardware cloth (Metal wire) in a circle and then put a square on the top. It will hold a good sized pot with ease. I will have to post a picture. Also Make more than ONE - when one runs out of fuel - simply insert the next one to keep cooking. Mine runs about 7 minutes too.<br>
I have a Swiss volcano stove that you can use any type of burner / fuel in. This works great. I used to use the small cans of Sterno in it but at times it would burn out before the water was boiling. Now I only use one of these. I use the Fuel line defroster known as &quot;HEET&quot; it works absolutely perfect and it is cheap. I buy mine at Walmart for $1.39 per 12 oz. bottle. Also if you take a small coffee can and cut the top and bottom out then using a old style can opener &quot;the one that punches out triangle holes&quot; punch holes all around the top edge and a few around the bottom for breathing holes, it makes a great wind break and pan support.<br><br>Oh and Great Instructable, this has many uses and could cook food during a power outage or other disaster.
just like gas powered stove top has a metal plate for the pot to rest above the flame, you would need to supply some sort of elevated support and not put the pot directly on the stove or it may be crushed. In the video he had the stove inside a larger pan ( looked like a cookie tin) and on top of that placed a metal wire ...dunno what it's called...and sat the pot on top of that. This is a good question to ask because I've seen examples where people placed the pot directly on the stove and that seems very unstable and dangerous to me.
Three rocks of the appropriate size and in the right locations around this burner will keep your pot stable, but they will also stop the flame holes from being blocked by the pot. They may also be oriented to provide a wind shield if that is an issue.
this is the most practical one i have ever seen, and surely simple to make. Well done.
Thanks!
By the way, the site&nbsp;<a href="http://zenstoves.net/" rel="nofollow">zenstoves.net</a>&nbsp;has many, many, many variations on these little stoves.
Awesome.
one year ago...
That's pretty nice!
Nice stove, what does the coin do?
It seals the holes in the middle, it prevents the flames from getting out in the middle part.
how longs it burn? looks like a cool lamp, ad some scented oil and you have a centerpiece.
15 ml of alcohol burns for 7 minutes.
Cool and interesting. I've seen a lot of alcohol stoves, but I don't think I've seen one like this before. Good job.
<p>Aren't the cans made out of aluminum? Don't they melt?</p>
<p>Very nice instructional information. I have made several versions of the alcohol stoves. What you have called a &quot;Jet Stove&quot; I have seen called the penny stove. I have also made lids for various stoves to be used to snuff out the flame if needed.</p>
So cool! It was more challenging to sand than i thought it was going to be. Also, i had such a good fit between the halves i didn't glue them together.
<p>Thanks for the instructable! I made one and it worked well.<br>I did not find it necessary to use the coin. Without the coin, it just has two<br>more jets. I may make a second one with smaller holes (I used 1/16&quot; drill and<br>that might be a little large for clean burning, from what I have read). I used<br>8 holes around the perimeter. Might use 16 next time. And I think only one<br>center hole is needed, although it would be slower to fill. I was not sure if<br>the superglue would hold up to the heat, but it seems to be doing okay. Thanks<br>again!</p>
<p>Terrific idea for a small stoway in your daybag</p>
<p>I'm sorry am I the only one that noticed on step 4 , punch holes in top of CAN, not, holes will go in the top of burner part, don't do like I did poke hole in both ends, put two tops together , they are hard to separate, once there put together.. have fun </p>
What's a &quot;BROWNOUT&quot; I have heard of &quot;BLACKOUT&quot; but never &quot;BROWNOUT&quot;
blackout is a general term for power outage of any kind and/or complete outage of all kinds. <br><br>Brownout refers to a power outage where the phone landlines are still up, which most of the time btw have an electrical charge running through them rated at 40-70 volts, no idea about the amps though.
They are the same. Brownout is the traditional way of saying blackout in our country.
Thanks for clarifying that
Works really well. Thank You
<p>I'm glad you like it! :D</p>
<p>Thanks for idea and design, we will be using it this coming weekend for the freedom Climb... :) the best talaga inventions mo thumbs up!!!</p>
<p>I never thought of someone actually can make some kind of stove through coke Can. I have read some of the <a href="http://bestalcoholstove.com/" rel="nofollow">alcohol stove reviews</a> , they're inspired me more. I will try this!</p>
Very nice. I would substitute the CA, or superglue for a thin bead of silicone sealant.(before you put the two halves together.) It will stay flexible, it's impervious to chemicals (what makes it great for automotive gaskets..) and it's heat resistant to around 400 degrees F.<br>Keep up the good work.<br>T&gt;
<p>If you check in a hardware store, like Lowe's, Home Depot, or Menard's, they usually keep heat resistant silicone by the wood stove/fireplaces and it is good for 2000 degrees Fahrenheit. I'm in the process of making a kiln &amp; looking at some to fasten the bricks together. </p>
In step 10: Seems like you spill a bit of alcohol in last photo.. <br>P.S: Blue flames are hotter then Yellow flames...
good... it's very hott
I've done a similar design, but also made a modified from the 2-bottom design. Mine only uses 1 can. The original version I built from someone else's plan, you cut out the center of the top piece, inside the ridge, so it was totally open. (aside form the rim with had the jet holes, and the solid inside rim, you basically cut-out the concave disc.). Then you cut a strip of the can side form the left-over, clipped it a little shorted in diameter, cut a few &quot;^&quot;'s in the bottom to allow alcohol to flow to the outside of the strip), then stuck it between the rims (top &amp; bottom, with the notches towards the bottom).. the idea, light it.. Once you got the jets lighting, place the pot you wanted to cook on top., but held it slightly above til it got hot. then place the pot on top of the entire stove, and the heat would travel down the strip inside, to maintain the vaporizing fuel from the jets. The version I designed, instead of a 2nd can, you dod the top, removing the center plate with the pull-tab, and cut the side just a 1/4&quot; shorted. then, same thing, drill holes through the outer edge of the rim. reacted the same way! and only cost $0.05 <br>
I've made a few of these, and they can be pretty fun. I have a few tips that may help. <br> <br>I usually dont remove the paint, but if you want it to look real nice, polish the can (before you open, so its pressurized inside) I used white polishing compound, and the can comes out shiny like a new penny. <br> <br>I just use a push pin to make the jet holes, its quick and easy, and the right size. <br> <br>We experimented with different fuels, but found that rubbing alcohol seemed to work best, even if it didnt last as long as we would have liked. <br> <br>You can a cotton ball inside the can to help reduce spilling flaming fluids around. <br> <br>You can make a wind screen out of another, larger can (cut the top and bottom off, then make holes in the side for air), that also works to hold a pan over the stove. <br> <br>
Hey, <br> <br>I didn't seal it. The fire is come out from the unseal part. <br> <br>Brandon
You can use high-temp epoxy from your local hardware store, I'm sure they have it. BTW, great build. My version #2 is similar, I'l post it next week :D
About This Instructable
243,516views
957favorites
License:
Bio: Hi I'm Angelo! I am a 18 y/o college sophomore taking my majors in BS-ECE at the DLSU. I use my course as ... More »
More by ASCAS:Build A Bluetooth Boombox Speaker (from scratch)  DIY Life-Size Phone Controlled BB8 Droid Rig A Car Horn To Your Alarmclock!
Add instructable to:
