DIY Jumper Wires (male to Male)
Introduction: DIY Jumper Wires (male to Male)
A jump wire, is a short electrical wire with a solid tip at each end (or sometimes without them, simply "tinned"), which is normally used to interconnect the components in a breadboard. Follow this procedure to make your own.
Step 1: Gather the Requirements
Step 2: Measure and Cut Wires From the Ribbon
Make the length to suit your requirements.
Step 3: Separate Every Header Pins and Wire
Step 4: Strip the Sleeve and Twist the Wire
Step 5: Fix the Header Pin in Octopus. Check the Link for Build Instructions -->> Octopus
Step 6: With the Help of Helping Hands Solder the Pin to Wire
Apply flux
Tin the tip
Step 7: Insert Heat Shrink Sleeve and Shrink It With Hot Air Gun
Step 8: This Video Might Help You
Step 9: Happy Bread Boarding.
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    I have done this before , but now I use cheap dupont jumper crimp to void paintful soldering. Another option , buy dupont jumper wire ( even cheapper than buy crimp!) , cut by half and extend with your wire.
    he, may be. I think my material quality not good so it not easy to stick the wire to tiny pin. If i solder too long -> the plastic melt down. I just find it much easier to use crimp, fast and clean.
    Yes that plastic piece will melt down and change its position. Apply optimal heat to avoid that situation. Practice will help.
    yes, that basic skill need practice .
    You can also use staples to form shorter connections between pins on a breadboard
    That's a new information. Thanks for sharing
    These are great for prototyping! Nice DIY jumpers.
