Nepetalactone is the active ingredient in catnip.* Today we are going to isolate nepetalactone in its pure form through a steam distillation. The distilled liquid will be extracted with an organic solvent (toluene), refined, then evaporated to give the final product.
Now I know what you're thinking: is it safe for cats to be around such a concentrated extract of catnip? Hell yes! Within reason. And we're all reasonable people. Pure nepetalactone has been studied on cats extensively. In fact, "catnip oil" that is available from botanical stores is essentially just nepetalactone, and it is widely used in homeopathic medicine. More details later.
- Note: pure nepetalactone will not enable you to create a cat army.
Step 1: Crash course in steam distillation
This is particularly useful for extracting plant matter, where the steam serves double duty, breaking open cell walls and releasing volatile oils like nepetalactone. A standard apparatus that you would use in a chemistry lab is shown in the first picture below. Of course, we'll be doing this at home without access to fancy science gadgets.
For this catnip extraction, I've constructed a much simplified apparatus shown in the second picture. The catnip and water goes in the bottom of a big pot, with a cup placed on top. The lid is really the key component here; by simply turning the lid of the pot upside down, the vapors will condense and drip down from the center, collecting in the cup below. By filling the top of the lid with ice water, the vapors are condensed very efficiently.
Step 2: Obtain the necessary materials
-1 pound of catnip, available online for bargain basement prices. I paid $3.40/lb from the San Francisco Herb Co.
-1 turkey baster (this will be an improvised pipet)
-1 eye dropper, available from the drugstore
-1 nalgene bottle that you are willing to sacrifice to the cause. It will never be the same. A glass mason jar also works, and it would be more robust.
- toluene (available from the hardware store in the paint thinner section)
- a large pot with a glass lid. It's important that the tip/handle of the lid comes to a sharp point in the center, like this one.
- vegetable steamer
- salt
- baking soda
- coffee filters
- a funnel
- shot glasses and a glass cup
- plenty of ice (5 lbs or so)
Step 3: Prepare the steam distillation
Place the glass lid on top of the whole assembly, upside down.
Step 4: Check the fit of the lid
Before actually starting with the catnip, do a trial run by filling the pot just with water to make sure you can distill effectively.
Step 5: Start distilling
Once the steam starts to condense on the lid, cover it with some of the ice. This will help condense the vapors more efficiently. To put some hard numbers on it, my distiller was able to condense ~10 mL in 15 min when I had the lid just cooled by air. But with ice on top, it condensed ~100 mL in 15 min.
The ice will melt as the steam condenses, hopefully collecting in the glass in the center of the pot. This is good.
Step 6: Collect the distillate
Add a little more fresh water to the mush to replace what you've just removed, put the lid back on, and cover it with a fresh round of ice.
Step 7: Repeat steps 3 through 6
Cover that with water and extract exactly as before, obtaining 3 x 100 mL of distillate, to give you 600 mL total, combined with the first crop. Then do the procedure with the last 1/3 lb catnip, giving you 900 mL of combined distillate.
This procedure will take a few hours, but it's not very labor intensive. It basically involves checking on the operation every 20 minutes or so to collect the distillate; the perfect time interval to be watching TV, reading a book, or rounding up stray cats for your impending CAT ARMY*. Also, you can take a break and turn it off whenever you want.
Step 8: Extract out the organic material
To get that out, we're going to do an organic extraction. Nepetalactone is a non-polar molecule and is much more soluble in an organic solvent than in water. Toluene is convenient because you can get it at the hardware store, and it's not especially bad for you. You could also substitute something like diethyl ether, if you can get your hands on it.
First, add a large quantity of salt (about 1 cup) to the water and shake it up real well to dissolve it. This increases the ionic strength of the water, giving the nepetalactone even more reason to dissolve in the toluene. Add 1 shot glass worth of toluene to the solution. Close the nalgene bottle tightly and shake it really well for at least a minute. Allow it to stand for at least 15 minutes, until you can see two distinct phases in the liquid. It's not clear from this picture, but you should see a thin layer of toluene floating on top of the water. It may be a little murky but that's OK.
A side note, don't let this mixture stand for *too* long, because the toluene will start to degrade the plastic and fog the nalgene bottle. Not an issue if you're using a glass container.
Step 9: Separate the toluene layer
Repeat by adding another "shot" of toluene to the catnip water in the nalgene bottle. Shake it up really well, let it separate, and use the turkey baster to suck off the top layer, placing it into shot glasses. When you're done you might end up like me with an array of shot glasses, mixed with toluene/water.
The mechanical action of transferring the liquid to shot glasses seems to help the layers separate further. The ultimate goal is to get rid of the water layer entirely, giving a clear toluene solution.
Step 10: Refine the toluene extracts
Use the eye dropper to remove the top toluene layer from all of your shot glass mixtures, transferring it to a new shot glass. Avoid sucking up the bottom water layer as much as possible. You should now have a shot glass full of still-murky toluene. Add a little bit of fresh water and stir it up really well with a stick. This will hopefully wash out some of the stuff that causes the emulsion.
Now, remove and discard the bottom (water) layer with the eye dropper. What's left behind is a cloudy toluene solution that we will clarify in the next step.
Step 11: Dry the toluene solution
- Have I mentioned that I am a MAN OF SCIENCE? Invest your tender faith in my finely honed skills!
Step 12: Filter off the salt
Use the eye dropper to put the toluene/salt/junk solution on the filter and let it all pass through. What comes through the other side may be tinted a little yellow or green, but it should be clear and water-free.
Step 13: Optional sodium bicarbonate wash
Prepare a base solution by dissolving 1 tbsp of baking soda in 1 cup of water. Add a volume of this approximately equal to the amount of toluene you have. Stir it or shake it up really well for a minute, then allow the layers to separate. Use the eye dropper to remove the bottom water layer, which contains the impurities. Repeat the wash with a fresh portion of base-water and again remove the bottom layer.
The toluene solution that you're left with after this washing sequence now has a little bit of water in it, so we'll need to clarify it again, as in steps 11 and 12.
Step 14: Re-clarify the toluene
Ultimately, you end up with a very clear liquid that contains nothing but toluene and nepetalactone.
Step 15: Evaporate the toluene
Step 16: Admire your product
Furthermore, this material is extremely pure. I analyzed it using gas chromatography/mass spectrometry, and found it to be >99% nepetalactone (see the second image below). In the chromatogram, nepetalactone is the giant peak around 12 min with a molecular weight of 166, and it's the only peak that is visible. For comparison, a sample of "catnip oil" that I purchased online was only about 80% nepetalactone (third picture).
If your sample has any amount of solid material mixed in with the liquid, most likely that is nepetalic acid. You may see that if you chose to omit the base wash from step 13. It's OK and isn't going to harm anything.
Step 17: Find a cat
A note about safety. Yes, it is safe to use this extract on cats. I have looked into it, and there are a number of studies (very interesting in their own right) using pure nepetalactone on cats in experiments trying to figure out why it causes them to go bonkers. The upshot is that it's pretty safe. In the last of the references below, the LD50 of nepetalactone was determined to be 1550 mg/kg (about the same as aspirin), meaning you would have to force feed your average 5 kg cat ~8 grams in order to cause it any harm. So as long as you are reasonable with the extract it should pose no harm.
If you are interested in learning more about the chemistry of catnip and nepetalactone, may I suggest the following primary references.
nepetalactone isolation and characterization:
J. Am. Chem. Soc. 1941(63), 1558-1563
J. Am. Chem. Soc. 1942(64), 1828-1831
J. Am. Chem. Soc. 1955(77), 1599-1605
behavior/metabolism/toxicology studies on cats
[http://dx.doi.org/10.1016/S0163-1047(85)91151-3 Behav. Neural. Biol. 1985(44), 38-46]
Science 1969(164), 1281-1282
Lloydia 1978(41), 367-374
Finally, I would like to acknowledge Dr. David C. for his kind donation of a GC/MS reference sample, laboratory helper Melissa A. and most importantly, Mer, the intrepid kitty with an appetite for catnip.
Visit Our Store »
Go Pro Today »
"Heisenpurr."
"You're Goddamn right."
That's science being used for utterly important purposes. :) Seriously, most nerdy/crazy scientist/resource overkill statement I heard the whole year (as if distilling catnip wasn't already overkill)
Btw, I would do the same if I had a mass spectometer laying around. I'm just envious. :]
This statement says to me that you aren't fully grasping how much fun you can have being entertained by super happy high cats. Twice as much diethyl ether would be worth half of the fun of seeing a cat fight his nemesis, a stuffed animal from a claw machine...
But seriously, cats love this stuff...
you can try heptane
Just wondering whether you could omit this step by including some base in the initial salt-out. I guess the nepetalate salt might emulsify the mixture a bit more but it would save the extra step and the losses in washing & drying again if you could avoid the separate washing step.
Just a thought.
I highly appreciate how clear your instructions are; I would have expected instructions for a distillery to have possibly a few steps that left me guessing what I'm supposed to actually do. Other guides I'd read (not on this site,) about getting an extract had this tendency to assume, "Okay, now that step 2 is done, you do the usual thing, and then it's time for step 4!" which left me going "wtf what happened to 3."
So again, thank you for making such a concise intructable. I'm planing on growing my own catnip, and this guide is going to come in handy a few months down the road...!
BLASTED!
I just love this title; can't stop laughing at it. I just keep reading it over and over.
:P
TRI HOLER!
