Step 8Extract out the organic material
To get that out, we're going to do an organic extraction. Nepetalactone is a non-polar molecule and is much more soluble in an organic solvent than in water. Toluene is convenient because you can get it at the hardware store, and it's not especially bad for you. You could also substitute something like diethyl ether, if you can get your hands on it.
First, add a large quantity of salt (about 1 cup) to the water and shake it up real well to dissolve it. This increases the ionic strength of the water, giving the nepetalactone even more reason to dissolve in the toluene. Add 1 shot glass worth of toluene to the solution. Close the nalgene bottle tightly and shake it really well for at least a minute. Allow it to stand for at least 15 minutes, until you can see two distinct phases in the liquid. It's not clear from this picture, but you should see a thin layer of toluene floating on top of the water. It may be a little murky but that's OK.
A side note, don't let this mixture stand for *too* long, because the toluene will start to degrade the plastic and fog the nalgene bottle. Not an issue if you're using a glass container.
Besides. It's just a cat. Experiment goes wrong...get another cat.
That's really nice of you.
"The fumes can travel across tabletops and floors quite some distance before reaching an ignition source, then nasty things happen fast. We don't turn light switches on or off when this is in use, there's a chance of triggering an explosion." Really? Source on this? Sounds overly dramatic.
While using diethyl ether in Grignard Reactions I never had to worry about this.
The risk here appears somewhat exaggerated. Certainly it's flammable and with a low vaporization point. Maintain adequate ventilation, use steam or boiling water to heat the ether, and otherwise do your homework.Be guided accordingly.
"Toluene is added to gasoline, used to produce benzene, and used as a solvent. Exposed to toluene may occur from breathing ambient or indoor air. The central nervous system (CNS) is the primary target organ for toluene toxicity in both humans and animals for acute (short-term) and chronic (long-term) exposures. CNS dysfunction and narcosis have been frequently observed in humans acutely exposed to toluene by inhalation; symptoms include fatigue, sleepiness, headaches, and nausea. CNS depression has been reported to occur in chronic abusers exposed to high levels of toluene. Chronic inhalation exposure of humans to toluene also causes irritation of the upper respiratory tract and eyes, sore throat, dizziness, and headache. Human studies have reported developmental effects, such as CNS dysfunction, attention deficits, and minor craniofacial and limb anomalies, in the children of pregnant women exposed to toluene or mixed solvents by inhalation. Reproductive effects, including an association between exposure to toluene and an increased incidence of spontaneous abortions, have also been noted...."
http://physchem.ox.ac.uk/MSDS/TO/toluene.html
I also like the ether option though my preference would be towards using ethyl acetate as the extraction agent. It isn't as high boiling, as biochemically dangerous or as water-soluable as toluene.
The other mentioned option, diethyl ether, is more flammable and lower boiling. It can also overwhelm a person easily if used in a confined space. Caution. Caution. Caution.
Important!: I do my butane THC extractions into a bowl of water, instead of onto a plate. The water helps purify my end product which I scrape off the surface of the water with an old credit card. Impurities and toxins fall to the bottom while all potent oils stay on top of the water, awaiting your collection.
Toluene? No way! I've used Everclear to extract THC prior to using butane and it's almost as good as supercritical butane extraction. Since you want to use a solvent with little to no water for best results, simply boil your Everclear and herb in a pot 'inside another pot' of water (simple double boiler to protect the Everclear from getting too hot and combusting). Boil it for three-four hours and then strain it through coffee filters onto a plate or glass cooking dish that you will evaporate the solvent from. Use a hairdryer to gently move the Everclear around the glass pan (carefully!) and it will evap off the Everclear within minutes. Scrape & Enjoy. This will strip off all essential oils from most plants, including cannabis.
For more on how to build a simple supercritical butane extractor go here:
http://www.erowid.org/plants/cannabis/cannabis_info13.shtml
To buy one already constructed for just a few bucks (recommended) try here:
http://weedcity.com/shop/product.asp?numRecordPosition=5&P_ID=402
For a complete guide on this form of plant oil extraction, this is well written:
http://www.uk420.com/boards/index.php?showtopic=3659
Hope this helps and don't forget to always grind your plant matter into bone dry powder for the best yields in your extractions.
PHDinTHC
PS: If you're hellbent on using either, don't use starting fluid unless you know how to separate the ether from the other compounds in starting fluid. I've pulled straight ether out by taking a can and spraying it into a jar filled halfway with tap water. Shake vigorously for several minutes. The water and ether layers will then separate easily.
