Introduction: DIY Korner | Home Security Based Product
Picture of DIY Korner | Home Security Based Product
Hey techies,
Techiesms is back with another amazing project article. This time, we have break down one home security based product called Korner and turn that down into DIY project. In this article I have covered almost all the aspects of this project from hardware components to software coding. So let's get started.
Step 1: Intro Video
I have made one intro video, so those who don't know what is korner and how does it works, first watch out this video and then move further.
Step 2: Hardware Components Required
Picture of Hardware Components Required
For Korner Stick you'll require,
  • ESP8266 12e board
  • Piezo Buzzer
For Korner Tag you'll require,
  • ESP8266 12e board
  • 3-axis accelerometer
Step 3: Circuit Diagram
Picture of Circuit Diagram
Hardware Connection for korner stick and korner tag are shown in the fig.
Step 4: Concept Used for Making This Project
First of all, the main part of product Korner are
Korner Stick & Korner Tag
So the concept I used for making korner stick is, first of all this stick need to provide an access point(in simple language,creating an hotspot) to all the tags to get connected to it and in parallel the stick needs to get connected with our router so that the stick can get internet access to send notifications to laptop or mobile phones via Adafruit MQTT Server. So I programmed this ESP board into Mode 3(Both Station and Access Point).
After the tags get connected to the stick, the stick will be waiting for particular links to get requested from the tags. If that particular link is recognized by the stick, it will first send signal to MQTT broker and start buzzing the buzzer 10 times. This is the task done by the ESP board acting as a stick.
And for the korner tags, I have programmed the ESP board to work in Station mode as it just need to connect to our korner stick. After that, the values of the accelerometer gets calibrated according to the surface it is attached on. So, whenever there is any movement of the door, the values of accelerometer gets fluctuated and the ESP board acting as a tag will request one link and that link depends upon the IP address assign to the korner tag.I have explained this concept in very much detail in the project video so watch out to know more.
So this is how I made my own Korner Stick and Korner tag.
Step 5: Code
Code for Korner Stick and Korner Tag is available on my GitHub account, go ahead and download it from there.
Step 6: Project Video
I have also made a project tutorial video of this project and I have also shown live working of the project. Have a look to the video.
About This Instructable
1,192views
29favorites
License:
Bio: I am trying to learn as many things as possible in this field of electronics. And further trying to teach in as simple way as ... More »
More by techiesms:Monitoring 16 Analog Sensors Data Using ESP8266 12e BoardConnected LED Lamps | IoT Projects Controlling Appliances With Google Assistant
Add instructable to:
