3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY LCD backlight
DIY LCD backlight
This simple method lets you make LCD backlight of any color and size to bring new look to an old device.
Step 1Let's make something.
Let\
For this job you'll need piece of transparent plastic, LEDs, resistors and some wire plus good set of different tools and couple of straight hands ;-)
57 comments
1-40 of 57next »
Dec 7, 2010. 2:27 AMhyaki says:
thanks man!! ;)
Dec 6, 2010. 4:41 AMhyaki says:
Hello,
Very cool tutorial!
I have some question:
Where did you get that plastic plate?
Can I buy Online with custom thickness?
Thanks
May 29, 2008. 7:58 PMYerboogieman says:
i tried this with a transistor radio and cracked the board opening it
Jun 22, 2010. 9:28 PMzack247 says:
how hard is it to find one of those? ive always wanted one.
Feb 2, 2010. 5:43 PMChromatica says:
Your Smart.
May 10, 2010. 2:50 PMvandiesel says:
You're a D-bag
JK
Feb 2, 2010. 6:40 PMYerboogieman says:
Aren't you perfect. Smartass.
Feb 2, 2010. 6:57 PMChromatica says:
>clap clap<
Good comeback
Feb 2, 2010. 5:42 PMChromatica says:
Cool.
First LED project?
Sep 11, 2009. 1:49 PMjunits15 says:
where can I learn how to use an lcd display?
Sep 13, 2009. 12:59 PMjunits15 says:
thanks
Aug 31, 2009. 2:02 PMrami123 says:
very nice!!!! i go to add backlight to 11 controls of Air Conditionals in my house! i think to use SMD Leds
Nov 11, 2008. 11:42 AMaskaquestion says:
Just wondering if anyone in here had experience gluing a layer of glass on a LCD screen with UV glue? If so, I would love some advice on how to do this with little to no spill-over so that it doesn't get into the circuit board components that are around the edges of the LCD screen itself. I have heard there are issues with applying pressure to the LCD screen with anything heavier than just the glass itself so I was wondering how to calculate the right amount and placement of the UV glue if I cannot apply any pressure to spread it out....
Sep 11, 2008. 8:36 AMripprasternode says:
Picture and text show polarizing filter below the plastic lighting plate (if you removed it by mistake). If the filter had not been removed it would be above the plastic lighting plate. What is the reason for this layering change or is this a typo?
Jul 25, 2008. 1:20 AMe22karol says:
It looks goods
Apr 13, 2008. 3:40 PMNJB says:
Very Nice! I'll have to try this with my old GBA if I can muster the courage to meddle with it's guts... (and find it in the first place!) A thought for the analogue meter, if you replaced the Backlight LEDs with UV LEDs and then coated the needle in UV-reactive paint (or a mixture of glue and glow powder) then you'd easily be able to read the value even in the dark!
Feb 20, 2008. 12:53 PMhumexavier says:
can you make A LCD DISPLAY OUT OF LASER TRANSISTORS OR A LED LIGHT change colors faster with a LED laser diode to work like other light sources?
Jan 21, 2008. 1:06 AMWhatnot says:
Not to quibble but the reason old analogue meters have the reflective strip is so that you can line up your eye with the needle and its reflection and thus avoid erroneous readings caused by the distance between the needle and the scale and the angle at which you look at it. Not that that always matters but I thought it might be an interesting titbit.
Jan 28, 2008. 5:41 PMThe Real Elliot says:
Have to admit I never wondered (enough) what the reflective bit was for. Now that I know, it's an elegant solution to an obvious problem. Thanks.
Jan 22, 2008. 7:47 AMpcairic says:
The word you are looking for is
parallax : the apparent displacement or the difference in apparent direction of an object as seen from two different points not on a straight line with the object; (Merriam-Webster)
Jan 23, 2008. 10:32 AMWhatnot says:
Not quite, although I could have used parallax in the description it would not do on its own and I was deliberately more liberal with words to make it clear anyway. So I wasn't really looking for the word parallax :)
Jan 22, 2008. 7:49 AMpcairic says:
Great instructable! I wish there was a way to make the light reflect more evenly.
Jan 21, 2008. 5:07 PMCameronSS says:
Why bother diffusing both sides of the plastic? If only the front side was diffused, wouldn't less light leak out the back? Apologies if I sound ignorant, I haven't done much work with optics.
Jan 12, 2008. 4:37 PMhondagofast says:
How easily could you replace the florescent backlight tube in the LCD screen for a laptop with LEDs? They are the biggest power hogs on any laptop...
Jan 21, 2008. 3:19 PMPunkguyta says:
It's been done many many times, time and time again. Don't bother googleing, just do a search Here
Jan 21, 2008. 4:19 PMhondagofast says:
That link doesn't work. :P
Jan 22, 2008. 9:06 AMPunkguyta says:
*shrug* Does for me
Jan 18, 2008. 2:21 AMLocalghost says:
one can probably use smd pure white LEDs, similar to the ones used for cellphone backlights.
Jan 21, 2008. 5:05 PMLinuxH4x0r says:
Hackaday!
Congrats
Jan 21, 2008. 8:47 AMevilution says:
I have done similar to this in the past but I used PLCC-2 Tantal surface mounted LEDs or 4x4 right angled SMD LEDs. A little bit harder to solder but take up less room and they give out more light than most rectangular LED packages.
Jan 15, 2008. 7:06 PMincorrigible packrat says:
I dig the meter. It looks a little unhappy, though. Does the sad-face part still make a reflection of the needle, so as to eliminate parrellax error, when reading it?
1-40 of 57next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
90
Author:AP Digital light
