3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY LED Plexiglass Heart
Ever since I saw this awesome doorthis awesome door awhile ago, I wanted to make something like it for myself. Well, i decided I would try on something on a smaller scale, so a framed heart for a special someone is perfect.
Step 1Decide What You want to make
For me, this was easy, a heart. But you're not stuck with a heart, you can make whatever you want, a flower, a star, a tree, anything. I would suggest you keep whatever you are making simple at first, this way you can get a hang for etching the Plexiglas.
34 comments
Apr 12, 2009. 6:50 AMLastDevil says:
i think it looks good, you done well there. If next time to do one (this takes a little more time) if you print out a picture then cut it out, glue it to a bit of ply board and saw the shape out. then place the ply on the perspex and use the engraving tool on a slow setting (if not by hand) and slowly go round the shape you plan on a few times it will have a clean indentation of the shape but looks good.
Jan 2, 2009. 7:49 PMchubbykai says:
Here is my version.
Jan 3, 2009. 1:57 PMchubbykai says:
haha i cheated a little. i bought RGB LED strips and a RGB controller from theledlight.com. heres some pics. i wanted this project to be something like "every time you look at it there's something new about it" type of thing. So i made a slot at the top of the frame so you can slide out a design and put in a new design. i used cherry wood and a stain and two coats of finish.
Jan 3, 2009. 2:02 PMchubbykai says:
oh i forgot to mention there are 9 LEDs per side. haha theyre super bright. the LED controller can adjust brightness, color, speed, and different modes of changing color. It also comes with a remote haha (might as well). Since the LEDs run off of 12V i had to get a converter to convert household 120V to 12V. So i went to Ikea and they have this LED lighting thing and has a little circuit board that does the job. cut off the cord and installed a dial switch to make it on off. I used the remaining LEDs for my car since the car runs off of 12V and wouldnt need a converter. tools i used: -compound saw that can miter and angle -table saw -super bonding wood glue -lots of clamps -orbital sander -router to make the slots -soldering iron any other questions feel free to ask!
Dec 5, 2008. 6:50 PMthe_better_nacho says:
this is what i did.. it originated as the "door" idea, using two pieces and two different color LEDs, but soon realized my then wiring method wouldnt work, so i did a 'mirrored' version more like yours. this is pre-spraypainting the frame, and 'Sikie' is my little sisters nickname; im making this for her xmas present and plan to make several more for friends and maybe one for myself.. just waiting on more colored LEDs _
PM or email me (lightcone15@yahoo.com) if youd like to see an 'ible on how i made this and how i will make more.
Dec 5, 2008. 6:52 PMthe_better_nacho says:
oh, and the color is actually 'purple' or 'ultraviolet', not blue as it looks in the pics - and the whole thing runs off of a 9volt battery i dremeled a cubby for in the bottom _
Apr 4, 2008. 2:55 PMHiddenKenshin says:
I love it! I'm going to try this and gather the parts tomorrow. However, I'm "technically challenged", meaning, I don't have acces to proper tools. So, are there any, more primitive ways to etch the heart? Manually? What would you reccommend?
Apr 5, 2008. 12:41 AMHiddenKenshin says:
No problem. Guess I'll have to resort to some tools. What exactly would I need and what kind of engraving extension? (got any international brands?) I'm sure we have one of those lying around, problem is, I'm Belgian and the technical terms aren't easy to translate.
Sep 21, 2008. 10:34 PMurbosssez says:
oh um ive done it with a hole puncher thingy i found it in a sewing kit it has a round wooden handle that curves into a metal lance like pin or u can just use a sharp pin head and if u have good hands, etch with that however the etching wont be that deep
Feb 14, 2008. 7:55 AMarnoldt says:
Heres what i made
Feb 15, 2008. 6:32 PMarnoldt says:
She loved it
Feb 13, 2008. 3:04 PMKazooie says:
So um, the acrylic really likes to melt around the engraving bit. It does this at all speeds. It's a pain because i have to keep wiping it off the caked up acrylic on the bit before it digs into the pane itself (leaving a blemish). Did you have this sort of trouble with plexi? Maybe i'm just drilling in too far?
Feb 11, 2008. 9:16 PMKcole93 says:
Your directions were perfectly easy to follow, and coupled with noahw's LEDs for Beginners I have begun my first project. I have been sifting through Instructables and now I'm hooked. I'll try and upload pictures as soon as I add the finishing touches. I stayed true to your designs as this is my first project. Thanks for the inspiration, I think my girlfriend will love it.
Feb 10, 2008. 8:59 AMbduffman says:
oi one thing wood glue would have worked better another thing looking at this and looking at a proget befor he sprayed it back and then re engraved the picture depends if u want the see thro look or if u just want the picture would also probley block u from seeing the leds at the bottem would look nice i think turned out well dude who ever u give that to will be pritty happy
Feb 10, 2008. 8:42 AMbduffman says:
u could have used the table saw to cut 45* angles and join them that way like a normal picture frame better finish just make sure u measure the inside first then go 45 from that point
was this for valentines nice idea
Feb 10, 2008. 8:53 AMbduffman says:
another thing watch wat switches u glue some arnt sealed ive seen a proget he glued a switch in and the glue leaked in the switch and wouldnt turn on lol so watch that ( sorry to pick at ur project i like it tho its nice work i probley wouldnt have done all this if i was building it its just if u sit back and watch some one u see wat they should have done )
Feb 10, 2008. 8:49 AMbduffman says:
trick with drilling place a scrap bit of wood under it when u drill thro it wont cause it to crack it wil just drill into the next bit of wood or drill smaller hole then start drilling one side but only a quater way then flip it over ( and follow the smaller drill hole like befor but all the way thro ) personaly first way is easyer and the holes will be perfect 2nd way they can be out a bit
Feb 6, 2008. 1:49 AMqultiq says:
I wonder if etching liquid and a stencil would light up
Feb 5, 2008. 9:20 PMOra says:
Another reason to make a CNC router. Great instructable!
Feb 5, 2008. 6:58 PMKazooie says:
acrylic works too right? (just not as strong?)
Feb 5, 2008. 4:06 PMGorillazMiko says:
This is really cool. I like how things can do this, it's awesome. Nice job, +1 rating. Also, your blue flashlight mod rules.
Feb 5, 2008. 11:26 AMklemci says:
The product is nice, i like the idea. Its very useful for all sorts of decorations. I might try this as soon as i get plexi :D
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:Deadly Computer
