3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY LED Police Bike Lights
In this tutorial I will show you how to make cheap and custom LED police bike lights. NOTE: I made these lights before, so the tutorial may not be very descriptive. If you have questions message me!
DISCLAIMER: I WILL NOT BE HELD RESPONSIBLE FOR THE ACTIONS OR CONSEQUENCES REGARDING THIS TUTORIAL. USE WITH CAUTION, IT IS A STATE AND FEDERAL CRIME TO IMPERSONATE A POLICE OFFICER.
Step 1Materials
Materials
First gather your materials. You will need...
perfboard (the size depends on how many LEDs your lights will have)
LEDs (mine are red and blue high intensity LEDs)
Wire (any gauge is fine. I would recommend 20-24)
Resistors (Use a calculator to determine the amount of ohms)
Heat shrink tubing (I used a variety of sizes)
Connectors (optional)
Switches (both toggle and momentary on)
Switch housing (I used a PVC T-connector)
12v battery source (I used an eight slot AA battery pack, but I will be installing a rechargeable battery)
Switch Flasher (SHO-ME EMERGENCY LED STROBE FLASHER 11.1005SF)
Mini zip ties (for attaching the lights to your bike/vehicle)
foam (optional)
Solder
Tools:
Soldering Iron
Drill
Pliers
Lighter
Knife
Wire stripper
38 comments
May 7, 2012. 7:40 PMjwarn123 says:
how many resistors did you use. and did you put one between every led. and where is the diagram?
Nov 17, 2011. 11:08 PMsmkent says:
This looks like a really cool project. A friend and I are going to build custom LED lighting systems for our bikes. Did you end up swapping out the AAs to a 12 volt battery? If so, what kind of battery did you use? Also, are the LEDs bright enough to be easily visible outside in the daylight?
Nov 20, 2011. 6:53 PMsmkent says:
OK cool, thanks for the info. My friend and I want to build brake lights/turn signals for our bikes, so we want them to be visible during the day (like car lights). Where would you look for a good 12 volt battery? I'll have to do some research ...
Nov 21, 2011. 2:25 PMsmkent says:
My friend and I plan to program an Arduino to control the lights, at this point I'm just concerned with the overall power source. If I get a battery with enough power I should be able to make it work. I'll have to look at Intellect batteries -- I'm willing to spend $60 on a good battery if it's rechargeable and will last for a long time.
Sep 13, 2011. 1:46 PMDJNASHA says:
diagram please big thanks
Sep 25, 2011. 7:55 PMDJNASHA says:
THANKS MAN I WISH I HAD THE SHOW ME FLASER ALL I GOT IS VELLEMAN MK 180 Two-Channel Hi-Power LED Flasher
Sep 6, 2011. 9:12 PMsgomes3 says:
Great instructions. I would like to give this a try. And if anyone is interested to know where you can find a SH-ME LED Flasher, can find it here:
http://www.swps.com/11-1005sf.html
Sep 8, 2011. 5:17 PMsgomes3 says:
Hey...i am curious..is it legal to ride with this light....i can see how no cars will ever mess with me...but I hope i dont get a ticket by the cops. Either ways...this is just too good man! I will build one for the heck of it :)). Thanks for sharing such awesomeness!!
Sep 8, 2011. 7:24 PMsgomes3 says:
Ah...never mind...i read the disclaimer. I think i will change the colors of LEDs to Red and Orange or some other colors. No biggie.
Jun 22, 2011. 11:16 AMTimNg26 says:
Hey! May I know where did you buy your SHO-ME EMERGENCY LED STROBE FLASHER 11.1005SF?
Nov 21, 2010. 12:09 PMpolmic96 says:
How did you wire the rear lights to the SHO-ME EMERGENCY LED STROBE FLASHER 11.1005SF?
Nov 20, 2010. 8:50 AMpolmic96 says:
How many resistors per light did you use?
Oct 29, 2009. 7:43 PMjetersaurous says:
ok, that oznium website is awesome, but what resistors would i need for blue LEDs and what one for red LEDs. what resistors did you use?
Jul 24, 2009. 5:01 AMSupremacy says:
Great guide. Planning on making a similar one for myself using yellow LED's. Also planning to document my steps.
May 21, 2009. 3:00 PMsensoryhouse says:
Not the most detailed instructions but great idea and project! Thanks for sharing.
May 21, 2009. 12:54 PMdchall8 says:
Where did you get your LEDs and what power rating are they?
May 19, 2009. 1:50 PMlemonie says:
Do people respect your authori-ty? L
May 19, 2009. 3:28 PMlemonie says:
I was referring to Eric Cartman, when he was deputised. You are wise to be aware of annoying the Police in your area - you've put the thought into this. L
May 20, 2009. 4:13 PMlemonie says:
Er, no. (warped sense-of humour).
I omitted to say that this is a good and well-presented build and that I rate it as such
L
sorry
May 19, 2009. 4:37 PMNachoMahma says:
May 19, 2009. 5:37 AMPKM says:
Hi C7mb,
Welcome to the site. This looks like a cool project (and not at all something I'd like to abuse :P). Just one tip- your ASCII art is a bit mangled because being converted to HTML removes multiple spaces. Drawn diagrams are ideal, simple line drawings in MS Paint are fine as long as they are readable, but if you want to do ASCII art then you can enclose text in curly braces to make it monospaced. Putting {{{ on a separate line before the text and }}} on a separate line after the text turn it into
monospaced text---------- ----where you can              have multiple spacesand draw diagrams+---+|   |+---+     \      \       \        like this one
To do that I typed
{{{ASCII     TEXT
Also, beware of the text parser turning more than four hypens in a row into a horizontal rule.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:C7mb
