Introduction: DIY: LED Workbench Light From LED Strips
This time I’ll show you how to make simple workbench light by using high CRI Yuji LED strips and piece of aluminium.
How I did it - you can check by looking DIY video or you can follow up instructions bellow.
For this project you will need:
Materials:
LED strip
Flicker free dimmable LED power supply
Aluminium profile
Tools:
Soldering iron
Drill and bits
6mm bolts and nuts
Cutters
Step 1: Materials
In this project I’ll use Yuji LED production: flicker free dimmable power supply and high CRI LED strip. I choose Yuji BC series 12V LED strip with color temperature of 5600 of kelvins. All Yuji LED production is unique, because of high color rendering index. This LED ribbon have CRI rating of 95. High CRI LEDs provide the best color rendering ability and that’s why they are perfect for photography and video lighting.
I’ll use an aluminium strip with dimensions of 3 by 25 millimeters and total 2 meters of length. Aluminium is the best solution to ensure proper LED cooling. Also it’s lightweight and cheap. Plus it’s very easy to work with it.
Step 2: Working With Aluminium
The idea is to form an illuminated arc over working area on my workbench.
Stand legs was made form L shape aluminium profile. Each was 30 centimeter length. Drilled a hole in a middle of stand legs and used it as a template to mark drilling point at aluminium arc. Stand legs and aluminium strip screwed together with 6 mm bolts and nuts.
Step 3: Small Adjustments
Made small adjustments to get proper shape.
Step 4: Glueing LED Strips
And the fun part - to glue LED strips. I’ll use two LED pieces of 125 centimeter length and glued them in parallel.
Step 5: Wiring...
Pretined and soldered both LED strips in series.
Made two holes for power wires and soldered them in place.
Connected power wires to solderless connector and zipped it to aluminium profile.
Step 6: Testing Time..
And the moment of truth!
Step 7: Summary
What’s great about dimmable power supply - thats I always could get exact amount of light when working and filming my projects.
One meter of this LED strip is producing up to 1300 of lumens and takes up to 18W of power. So my setup at max power should give up to 3200 of lumens and will take around 45W.
2 People Made This Project!
waynewen2003 made it!
vhajar made it!
18 Comments
Note Flexfireled.com also sells 12 high CRI LED light strips that are about 2x brighter than what I see on fuji website. CRI is an indirect measure of light spectrum coverage. High CRI LEDs cover most of the visible spectrum of light. A CRI of 100 covers the full spectrum. Most consumer LEDs are at about 70 to 80CRI. US Energy Star labeled LEDs must have a minimum CRI of 80.
https://www.flexfireleds.com/categories/LED-Flexib...
Unfortunately these high CRI lets cost significantly more than your typical LED strips.
LED flicker is mainly caused by by powering the LED with AC power. A well regulated 12 DC power supply will also produce flicker free light. Another source of flicker is from the dimmers often used in such projects. A good flicker free dimmer can be hard to find.
It's also my understanding that the higher the CRI the better the quality. Can you confirm this information? Thx
COOL GREAT PROJECT FOR ANY WORKBENCH!!!
Great Project
funny...i bought 3 led set of xmas lights for a light box...only needed two and am going to use the third and a split hula hoop for just this kind of light setup...must be steam engine time...thanks
nice I loved the idea and it's perfect for solving shadowed areas while working too. Will have to look at this idea some more for my work desk that's for sure
Thanks for sharing the idea.
excellent,simple & light,many thanks.
Nice... like the idea, and the portability, bring the light to wherever you are working... Where can you buy aluminum flatstock like that? Also, could you use PVC, and make something similar? Wouldn't look as nice, obviously, but function wise, would it do? easy way to hide the wiring as well?
I have been waiting for some one to make a high detail light system tutorial. I'm a Card Stock(Paper)modeler and at this time of the year when it gets foggy or cloudy it's hard to see at times plus getting an idea and wanting to work at night. This is a gift from God for me. My very deepest thanks for doing this project. This will really be a huge help. Thank you very much. wc
Great design, ive tried making a few lights but none of them has been satisfactory. I'll try this one and report back. :-)
