DIY LENS HOOD Box-Shaped [ Square ]
4,789
25
5
Published
Introduction: DIY LENS HOOD Box-Shaped [ Square ]
About: Hi, I am a low profile Indonesian. learn and practice is always fun for me. I am pleased with the design world. cycling, swimming, playing piano, and a little slack at the end of the week with a movie and a ...
Hi all,
This is my first DIY, a box-shaped lens hood for the camcorder.
with simple tools and materials around you, you can create a lens hood with the same functionality without spending much money. set aside time for this.
TOOLS :
- Paper cutter
- scissors
- a ruler
- markers
MATERIAL :
- cardboard
- Adhesive (super glue)
- (Spray paint - black DOV)
Step 1:
step I
FIN
create a line that forms the basis of the fin. would be easier if you create a basic form and make reference to the four fins are. Do not forget to add the distance in each of the fins on each side. this is to ensure that the form in order to remain robust.
HOLDERS
make the outer diameter of the circle according to your camera lens circle followed by a larger diameter (about 10mm larger). you may need two forms of the same for this section.
ARM
create a rectangular outline for the four arms measuring 30mm x 35mm (adjustable). The fourth arm serves as a sleeve between the fins and the holder.
step II
cut "cardboard" with follow the path you created earlier. then shape into a square of cardboard. Dab glue enough on the two arms meeting.
step III
raft every piece suit each function.
Step 2:
step IV
give the final touch "DOV" using spray paint. you can sand the board in advance of each field for more refined results.
* Some images of DIY lens hood square along with other equipment attached to the Canon HF10 mine.
so-and-so much, Happy DIY !
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    5 Comments
    GREAT DIY PROJECT for begin filmakers...
    of course it would be easier if you provide us the measures...
    thanks Ahhmado.
    that's Great project for my semester
    www.cheers4all.com
    http://www.cheers4all.com/ This site is awesome
