DIY Lab Bench Power Supply !
3,103
29
Posted in TechnologyElectronics
Introduction: DIY Lab Bench Power Supply !
About: Ideas Into Reality !
A Bench Power Supply Is Very Important Instrument For Your Electronics Hobby or Professional Work , Everything Needs Power Supply ! Under 60 $ It's Very Useful DIY Project For Anyone Interested In Electronics.
We're going to make a lab bench power supply rated at 216 Watts ,36 volts & 6 Amperes . Compact Size & Light Weight (500 Grams).
A Single Potentiometer interface makes it Really Easy to Use & Make as Well !
Here Are Technical Specifications.
Output Current 0~6A
Output voltage 0~36V
The voltage regulator / display resolution 0.01V
The minimum resolution of power Display 0.001W
The current regulator / display resolution 0.001A
The minimum resolution of capacity 0.001AH
Output Ripple ≤50mV
Watch The Video
https://youtu.be/b_mpgc_I5FU
Step 1: Parts List
Step 2: Connections Diagram !
1. Connect Switching Power Supply To The B3606 Power supply Module . Watch The Polarity Carefully !
2.Use Zener Diode To Run 12v Fan on 36 Volts .(See Circuit Diagram)
3. Make Sure That There's No Short circuit ! ( With Continuity Testing of Multimeter)
4. Use Hot Glue To Stick All Togather In a Desired Plastic Case
5. Refer This Block Diagram For Connections .
Watch The Video
Step 3: Make a Control Panel !
1. To Install this Power Supply Control Circuit To a Desired Location I Made This Extension cables.
2. Make Cut In Plastic Case For Display Buttons & Rotary Encoder.
3. The Hole For The Display Was Some What Messy ,So I Covered It With AntiStatic Bag & Transparant Tape . It Also Helps With The Better Visibility of The Display.
4. Then Hot Glue Switches ,Rotary Encoder & Display Module.
5. Double Checked Everything Works Good !
Step 4: Plug-It-In...
Plug It In & Do The Fun !
Here's The Specifications For This Power Supply
Input Voltage 6V~40V (For B3606 Module)
Output Current 0~6A
Operating Temperature ﹣40℃~+85℃
Display resolution 0.01V
Output Ripple ≤50mV
Have a Fun Guy's !
Take a Look At My Other Projects !
# B3606 Power Supply Module Review
https://youtu.be/uIfqRwkVOyk
# World's Smallest Power Supply !
https://youtu.be/0I_GVAxdO9M
# Mini Electric Screwdriver Keychain !
https://www.youtube.com/watch?v=zSlHaaxfR3M
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    2 Comments
    Can u give me the connection diagram of rotary encoder ?! Thank you !
    Can u give me the connection diagram of rotary encoder?
