3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Laptop Cooler
DIY Laptop Cooler
A plexiglass constructed notebook cooler equiped with spiffy lighted fans for some trippy late night surfing/gaming safari's..
Step 1Getting some stuff together...
You will need some stuff, so dig around in your parts drawer for the following items:
-a switch (toggle, SPST type)
-some wire (about 22g, roughly a foot or two, coated!)
-sheet of plexiglass or acrylic (a like the 1/4" stuff)
-2 comp. fans (standard 80mm or 120mm)
-some nuts and bolts (#8-32 x 1 1/4")
-old power supply (for this project I used an 24VDC from an old epson receipt printer)
-some tools (Dremel (of course!), hobby knife, Drill, solder gun, solder (the good electronic component stuff) heat shrink tubing, heat gun or blow torch)
41 comments
1-40 of 41next »
Jul 11, 2011. 8:27 PMnmaddux1 says:
i want to create something close to this but it is going to be built right into the side of the desk. sort of creating a laptop station with where i can hook up my two 23 inch monitor up to and keyboard and mouse....
anyways, i have three fans i just dug out of old computers and what not
two of them are identical and are: DC12v and 0.20A.
the third can is a little smaller (going to use it on the side as to suck the hot air out completing the airflow) but that fan is: DC12V and 0.12A.
I work at a hardware store so i have easy access to a SPST toggle switch, all the wiring, and power supplies.
But what power supply should i buy? The only power supplies i could find at home was an ACDC adapter which has:
Input: AC120V 60Hz 2W
Output: DC9V 100mA
would i be able to get away with this power supply?
any feedback would be great!
Feb 13, 2011. 7:47 AMnewbiest says:
If one is building a base from scratch, why not use a single big fan with a similar diameter to the laptop's length? :) Wouldn't it cool better while being quieter?
Mar 17, 2011. 4:49 AMZeroXL91 says:
You could, if you're going to do that use two Megaflow 200mm case fans from Cooler Master.
Mar 17, 2011. 6:33 PMnewbiest says:
yeah, 200 mm or even 250 mm would do the job perfectly :)
Mar 17, 2011. 6:04 PMnewbiest says:
Hello! I'm sorry for not answering earlier but when I got this email I didn't remember having signed up for this forum so I mistook it for spam. Now that I got a second email I finally realized it wasn't :P. Yes this would definitely be a big fan but size matters right? heheh ;) I just don't understand why don't manufacturers do that because it would probably be more efficient and quieter. But it's probably more expensive also... Far from sure but I feel that way
Oct 29, 2010. 11:50 AMryanboosh says:
im building one right now, and i just picked up 4 fans with these specs...
Rated Voltage: 12 volts
Operation Voltage: 10.2-13.8 Volts
Input Current: 0.15 Amps
Input Power: 1.8 Watts Max
but im not to sure what the Ohms ratings are on the fans. now ive found a few different power supplies lying around my house to choose from. here are thier specs.
Output: 12V- 1.66A
Output: 18V- 600mA
Output: 12V-1000mA
if anyone could help me out, that would be great :)
Mar 17, 2011. 4:51 AMZeroXL91 says:
It would be easier to just buy a 12v power supply from eBay with 2000MA, they're 5 bucks, just chop off the barrel plug, strip the heatshrink and wire, and viola!
Jan 30, 2011. 7:48 AMdylanw says:
how do you wire the fans in parallel and series
Sep 25, 2010. 9:00 PMfarfrmsane1211 says:
Ahahah non-skid action during quake tournaments, thats awome.
Great instructable BTW =D
Aug 8, 2010. 10:50 AMbgerlt says:
I have a question, still learning so be patient please.
Couldn't you power the fans through a USB port on the laptop?
Or would they draw to much power through the laptop power supply or battery?
Jul 28, 2010. 11:38 PMcylove says:
is there any codes, schematic diagram, circuit diagram for this? thank you in advance!
Mar 12, 2010. 10:56 AMcnorwood says:
nice i may have to try this at home or hack my 9 dollar cooler pad i hate i ever bought.
Jun 7, 2010. 10:55 PMzack247 says:
yes. those cooler pads stores sell surely arent very effective. the fans are in the same place on all of them
May 26, 2010. 12:02 PMshooby says:
I do a lot of work with plexi when making models.  Generally it's considered a good idea to heat it in a well ventilated area, because when heated plexiglass/acrylic gives off toxic fumes.  Don't fry your brain to cool your laptop.
Jan 15, 2010. 8:55 AMkevin07 says:
THANKS A LOT!!!!!
I made this cooler and it is great. It looks great but i think i am going to refine the electronics a little bit. Now my sister wants one :>)
Nov 9, 2009. 1:59 PMSmAsH! says:
have you thought about putting the fans in parallel?
then both could have 12v from a 12v supply...
Nov 9, 2009. 9:50 PMSmAsH! says:
Ahh, i see. Then its all good.
Mar 10, 2007. 3:33 PMteaaddict314 says:
(removed by author or community request)
Apr 7, 2008. 9:57 PMYerboogieman says:
plexiglass?
Apr 7, 2008. 10:08 PMteaaddict314 says:
plexiglass (or acrylic) is a form of plastic.
Mar 17, 2006. 9:20 AMNRoberts says:
Nice project, cool idea. One addition since your dealing w/ a laptop, you should make it more portable. What about making the fans USB powered. I forget what it puts out, something like 9v or so. Should still give you enough not to roast the boys if ya know what I mean!
Apr 7, 2008. 9:55 PMYerboogieman says:
5v 500mA
Jul 7, 2007. 5:35 AMslater101 says:
I made a portable one out of lightweight masonite and is powered by USB also... look for it HERE
Mar 17, 2006. 12:33 PMcolin says:
USB can deliver 500mA at 5V, so in order to run the fans at 12V you're going to need to use a switching regulator to upconvert the voltage. This can be done with a few chips and an inductor (I'll probably post an Instructable soon with the Eagle files) but your max current will drop correspondingly which means that you'll have a hard time driving your fans. Switching to lower voltage fans would obviously make it simpler.
Mar 10, 2007. 6:32 PMteaaddict314 says:
Apr 14, 2007. 5:43 PMFoiL says:
you could try putting rubber on the feet, or you can put tyhe fans at a lower voltage, lets say 7volts is enough
Nov 29, 2006. 3:27 AMkccupp_2000 says:
if you have a usb cord from a broken ipod you can strip it and use this to hook your fans up to it. that taakes carer of your power issues.
Sep 6, 2006. 6:53 PMIdentity says:
I too have an Alienware with a storied history of overheating. When I get the time, hopefully I can implement this. Thanks for the ideas.
Apr 1, 2006. 3:30 PMceebee says:
i actualy built a very basic one in my metalshop class. Basicly I just screwed a fan to the stand and took an old 12v adapter, striped it, wired it to the fan w/ a switch i bought at the hardware store. Its been working perfectly for over 2 years now and i run it almost constantly. I've got a powerbook (get very hot) and because its metal, just cooling the bottom surface actualy keeps the temp down at around 52ºC from 60º I didnt want to use a usb power supply mainly because of complexity and also usb uses energy wich = heat.
Mar 17, 2006. 10:04 AMpescabicicleta says:
For a lower-rent (and lower performance) but more portable solution, I took two of those rubber plugs that are used to protect sheetrock walls from door knobs, and attached them with a length snipped from a zip tie. Two of these work as a base for my laptop, lifting it off the table surface, allowing air to circulate, and thus keeping it cooler.
1-40 of 41next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:silverHalo
Jack of all trades, master of none, Sigh...... how does one get good at something when there are so many things in this world to learn?
