Step 4Fire Baby, Fire!
Next will be the 60 degree bend, it isn't approximate so just start heating and bending until you get the angle you want. I used another piece of wood flatten the crease by applying a bit of pressure until the plexi cooled enough to retain the shape I created.
For the final fold, I heated up the plexi, folded it under and left it to cool in the desired angle that allowed the unit to sit square on the table. If it wobbles while sitting flat you can use the heat gun to adjust the fold angles until it is right or just works for you. Also make sure you are folding the correct side, you want your fans to be exactly where you want them, not on the opposite side!
Add Comment
