Introduction: D.I.Y. Laptop Stands
About: A recent graduate in Electronics Engineering from NIT, Surat. India.. Interested in Art, Design n Technology. http://www.nirzaree.wordpress.com/
Well, laptop cooling stand is the essential thing if your laptop accidentally starts acting as an oven.. :P    is fuming hot air and making the surface irritable to work with.
So here is what I had made a month ago, to help my laptop.
All the stands here  are made out of MDF, a kind of wood.  Made them at a friend's woodworking shop.
You could make these of different materials, maybe thick cardboard or acrylic sheet or any other material which is at your disposal.
Items required :
  • a small sheet of MDF                    [to build the pad]
  • Band saw                                        [to do the cutting]
  • nails                                                  [to fix the joints well]
  • glue                                                   [pour at the joints]
  • DC Fan 12V                                     [optional but highly recommended! :) ]
  • USB cable                                        [to connect the fan to the USB port of the laptop]
  • Soldering iron
Important design tip :
Maximize open space while taking care of the required strength and convenience.
Step 1: Laptop Stand 1.0
This is the first pad that we made.
Simple, neat,easy to make! :)
  • Due to the open spaces, it allowes a lot of ventilation for the hot air.
  • The attachments on the front end are just to not let the laptop slip forward.
  • This is a non-foldable stand
  • It is a little difficult to sneak this one into a backpack.
Step 2: Laptop Stand 1.1
  • We added hinges on the side joints and in the center of the base to make a foldable pad.
  • It can fit into a backpack quite easily!
  • We also added a 12V DC fan for faster and better cooling.
  • We drilled a few holes on the chassis for more air flow.
  • The fan doesn't consume much current from the laptop so dont worry! :)
Step 3: Laptop Stand 1.2 [the Minimalist Design! :) ]
This is the latest version of the board that we built.
Additional materials required for this design :
  • Thin metal rods
  • Nuts and bolts
  • Small wooden cyclindrical spacers [to push inverted bolts onto those and  then put the spacers on the ends of the metal rods ]
Features:
  • Super light weight.
  • Super sleek
  • When dis-assembled, takes very little space!
So if you too have a laptop which is in bad health, then get going and make one of these..
Happy D.I.Y.ing!  :D
Fix & Improve It Contest
