3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Laser Spirograph
Step 2Setting up the Electric
Solder wires to one of the leads on both motors. Then solder both of those to one end of the battery. Next Solder a short wire to one of one of the motors leads. Attach a longer wire to the other motors lead. Solder the potentiometer to the short wire, solder a wire to that then connect that with the longer wire. Attach that to the switch then to the other end of the battery. The picture will help a lot.
Before anyone rant... I realize that anyone with any knowledge about basic electronics knows that electricity always takes the path of least resistance so wiring in a parallel isn't the best choice if I want to use a potentiometer. I wanted to only have to use one battery so I did. The potentiometer, if you're careful with it will change the speed of the one motor without stopping completely. If you want to wire in a series, it doesn't take too much knowledge to do that, so you can if you like.
Sorry for all the words.
1 comment
Oct 27, 2008. 7:07 PMLiberty92 says:
you should post a better layed out picture, maybe an obvious schematic or something to show a better view of the circuit
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:trooperrick
