3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Laser Spirograph
Step 7Closing Thoughts
Closing Thoughts
You don't need a switch as you can just twist and untwist two wires if you must.
The problems with wiring in parallel isn't too apparent here, probably because the potentiometer has pretty low resistance and i think it isn't worth it to wire in a series.
To keep the laser on, try using a zip tie over the button. The way the ties are made is that you can just twist them too and they will turn off the laser.
If you dont want to make the laser stand you could try to put the laser on a book or something to try and get the angles right. The instructable for using flour as a camera holder will work good, using a laser instead of a camera of course.
Please rate and comment.
If you want to go to a forum where you can learn all about lasers, go to Lasercommunity
A great place for high powered lasers is Wicked Lasers. Only buy lasers there if you buy goggles too, any laser over 5mW can be very devastating to eyesight.
Created by Lasercommunity member: trooperrick123
6 comments
Dec 3, 2009. 4:46 AMAlphaRomeo says:
Thanks for putting this wonderful instructable - I will make one as soon as I can
One possible modification could be that one could fix toothpaste caps (or something similar) to shafts of the motors - and stick mirror to cap using plastic clay or something like that.
Now you can experiment with different reflecting surfaces and materials - such as CDs or DVDs -
Apr 18, 2011. 10:38 PMcoolfordy says:
you could try small computer fans and bluetack
Sep 23, 2009. 10:55 AMshortwave says:
this is not a bad idea i wonder if we could add more to this like an arduino instead of brush type motors why not some bi- polar motors and servos to control the X-Y
Sep 20, 2009. 8:19 AMsupercrazytutorials says:
can i coonect it with the output audio jack of my pc???????
Aug 15, 2008. 3:22 AMchinnerz says:
yeah, i think this is a very good instructable. nicely done.
Jun 28, 2008. 5:20 PMwethecom says:
try this with slytle melted cds
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:trooperrick
