3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Lead Acid Battery Charger
Actually this could be used to charge any sort of battery where you want a constant current and a constant voltage.
In this instructable I will take you through the whole process to producing a final boxed system.
It will take an input from any AC/DC adapter with a jack. You simply have to make sure that the adapter is rated for the voltage and current you want to create. This system will allow up to 36V and 2Amps.
Step 1The Components & Tools Needed
Components needed are :
Project Box,
220nF capacitor,
100nF capacitor,
selection of resistors between 1and 5 Ohms,
5K/10K potentiometer,
820 Ohm resistor
Wiring - some jump leads ( suitable for connecting parts of circuit board together), some cable with two power carrying leads inside ( pos + neg )
Grommett
Crocodile/Spade clips
2.1mm or 2.5mm input jack ( depending on your power source )
Copper stripboard
L200C
Heatsink
The whole circuit revolves around the L200C current/voltage regulator ( the circuit diagram we will be sticking with is shown below ). You can download the datasheet from HERE
Tools needed are
Soldering Iron
Screwdriver ( Philips ) and a very small flatbladed screwdriver
Drill
46 comments
1-40 of 46next »
Oct 28, 2011. 10:13 AMoverclock999 says:
would i be able to use diffrent caps with this circuit, i have a bag of them that i bought but none in the nf range all of them are uf and the srcap boards only have 1nf and 10nf caps on them...
Jul 2, 2011. 1:13 AMdrwizbang says:
Yep, 100% American Made.
Feb 21, 2011. 2:18 PMmathieulj says:
The issue I was recommending caution with is not the circuit diagram as there is nothing wrong with it.
I was commenting on the fact that, for the resistance R3, the author used different value resistors in parallel to achieve a resistance equivalent to a given value (step 5). He then calculates a power dissipation as thought all the parallel resistors are sharing the current equally.
This is in fact false as, while in current limiting mode, the L200C will always hold pin 5 at 0.45V higher than pin 2 (in order to give you your current control). Hence the power dissipated by any of the parallel resistances in R3 is a function of it's own resistance (0.45^2/R_parallel).
Lets explain this in terms of what the author did:
In step 5;
To get a resistance of 0.625 ohm(for R3), he used a 1ohm, a 2.5ohm and a 5ohm.
So R3 = 1 / ( 1/1 + 1/2.5 + 1/5 ) = 0.625 Ohms
All is well so far...but then he calculates the total current to figure out power dissipation. However, having unbalanced parallel resistors, they wont equally share the current. In other words, if you have low value resistors, you have to calculate power dissipation individually.
For example, his three resistor will be drawing different currents totaling the value he calculated:
I3_1 = 0.45/1 = 0.45 Amps
I3_2 = 0.45/2.5 = 0.18 Amps
I3_3 = 0.45/5 = 0.09 Amps
I3 = I3_1+I3_2+I3_3 = 0.72 Amps
So although overall he is dissipating 0.72*.45 = 0.324 Watts as he stated, the first resistance is taking most of it at 0.45*0.45 = 0.2025 Watts (getting pretty close to 1/4 Watts resistor's limit). My word of caution is to not use too low of a value for any of the parallel resistors for R3 (since that low value will take most of the current).
May 1, 2011. 7:38 AMDelta25 says:
so what do we have to change in the schematics for it to be ok? can you expain i dont know much of electronics thanks you :)
May 2, 2011. 2:47 PMmathieulj says:
In essence, nothing. The schematics are A-ok. I was commenting on the fact that in step 5, the author replaces a single resistor in the schematic with a few resistors to give an equivalent resistance of the needed value. I then urged caution in the selection of these many resistors as pairing a very low value with a very high value will result in the low value taking most of the current.
Feb 21, 2011. 6:16 PMcoiley says:
You make the same excellent point. I would not have noticed the concern without your insightful comment. I only responded because your very relevant comment appears under step 1 - whereas the problem you very effectively address is not evident to the reader until they see the text and images attached to step 5. Comments seem to be exclusive to the project steps that they are posted under.
If I could make a suggestion - I believe that your important comment would be better understood if you proceeded to step 5 and then made the matter clear in a post there - in context. I feel that your comment would have more meaning to readers if they saw it under step 5.
Thanks,
-- coiley
Feb 22, 2011. 3:24 AMmathieulj says:
My apologies for that one. I see how it could be confusing on the first read of this instructible. I usually try to post under the relevant step but it appears that I neglected that step this time.
May 1, 2011. 7:37 AMDelta25 says:
mathieulj, i read your comment about a mistake in schematics, what would be whe fixed schematics without that error? sorry i dont know much about electronics :)
Oct 16, 2010. 8:57 PMmathieulj says:
You have to be careful with your unbalanced resistors in parallel. When you parallel resistors, the lower valued one will take in more current (and hence dissipate more power). With a 1Ohm resistor, it pulls 0.45V/1Ohm = .45A (0.45V^2/1Ohm = 0.20W) no matter what other resistors are in parallel with it ( since the L200 drives the current up to keep this voltage drop constant). With this particular selection of values, you are nearly overdriving a resistor. I am posting this as a word of caution for those who might have wanted to throw a lower value resistor into the mix.
Feb 21, 2011. 2:05 PMcoiley says:
You are referring to the authors choice of using three parallel-resistors-of-different-values for R3 shown in step 5. Gotcha.
I used two "identical" 1 Ohm 1W resistors in parallel. This is equivalent to a 0.5 Ohm 2W resistor for R3 - and the identical-resistors-in-parallel divide the current equally.
0.5 Ohm R3 makes for a 900mA max charging current.
May 19, 2010. 3:42 AMsasaa says:
LOL gotta love that :P
May 11, 2010. 4:54 PMmatstermind says:
could a different regulator be used as an alternative for the L200C?
May 7, 2010. 3:49 AMdahl327 says:
 does the voltage of the capacitors matter?
May 1, 2010. 3:58 PMmatstermind says:
could this be modified in some way to charge a 24v electric scooter battery?
Apr 4, 2010. 12:11 PMjimboa2020red says:
I can sorta follow you in this instructable, to a T atleast. But I lack the  understanding to modify this for say my drill. How would I gain sufficient expertise in this, as an electrician or something?
Sep 1, 2008. 7:22 PMXellers says:
If I wanted to charge some lead acid batteries with a solar panel, could I simply hook up the batteries in sequence and then hook them up in sequence with the solar panel and then add a diode to prevent the batteries from discharging through the solar panel? And if this does work, where would the diode go? I'm a bit confuzzled there. Thank you very much. :)
Nov 8, 2008. 10:36 AMvotecoffee says:
You'll overcharge them that way and lead acid batteries will sweell and burst or just die. Get a charge controlled rated for the amps or watts that the solar panel will put out. They make controller specifically for that. You can make your own controller, but the parts will cost you just as much as if you bought one from harbor freight. Also, is your solar panel made to output between 12 and 14? If it's higher it may be a 24 volt system or 18 volt system. Be careful. You want to charge lead acid batteries with about 13.5 give or take a little. If you have any questions, send me a message. Plus, if it is the right voltage, you want to hook the batteries up in parallel, not series. Make sure you get that right. If you hook them up in series, they'll only get half the voltage each and that can ruin your batteries.
Feb 12, 2010. 4:12 AMrk9bxr says:
I have two solar panels each of 60w and two batteries each of 12volts connected to an invereter of 24v microtek .I want to charge these lead acid batt. with solar panels and also with electricity one at a time my problem is solar overchrging to batteries . so please help me to show a way for stopping overcharging batteries.
Apr 29, 2009. 6:00 AMhalbertizzle says:
Heh, that and I love how it states right after the .7 amp max that this is less than 1 amp!
Mar 3, 2009. 4:19 PMvdanvung says:
nice one, wandering if u have done for 6v 12ah battery charger with led indicator when fully charge.
Nov 7, 2008. 2:59 PMjunits15 says:
where can I buy the L200C chip I cant seem to find it.
Nov 13, 2008. 1:21 PMjunits15 says:
will this charger stop charging when the battery is done? or is it just a trickle charger?
Nov 8, 2008. 9:33 AMjunits15 says:
i will, and is this just a form of a trickle charger?
Jan 4, 2008. 7:27 AMvotecoffee says:
Does that battery actually say 6.5 Bolts and not volts? lol I have a toaster over that says poewr and not power.
Nov 12, 2008. 4:13 PMjunits15 says:
XD XD XD and teachers say I spell bad! XD XD XD
Apr 5, 2008. 8:38 AMPlasmana says:
Thank you for that great Instructable!!! I will build that battery charger soon, you saved me ££££!
May 12, 2008. 2:27 AMPlasmana says:
I had built the SLA battery charger, again thank you for this great instructable! The first photo is the battery charger under test (charging a 6v SLA battery at 7v at 0.3A) and the other photo is the battery charger under construction.
Nov 8, 2008. 1:43 PMPlasmana says:
? The photo I posted on the comment before got deleted? I don't know that is going on...
Jun 6, 2008. 9:46 AMmattccc says:
will it shut off when the battery is charged pls reply
Jan 9, 2007. 11:42 PMdreimer says:
I was just wondering if there were a reference if the manufacturer is not known? I know the output of the battery, but do not know the charging specifications. 6V 5AH....it's for a bicycle light, if it matters....
Jan 4, 2008. 7:45 AMvotecoffee says:
What type of battery is it? Lead acid, NiCd Or NiMh? If it's NiCd or NiMh which I'm assuming it is being on bike and they go for lighter weights on bikes, you should get a smart charger for the battery. It's cheap enough just to buy one rather than build it and they're almost universal in that can be used for a lot of different batteries as far as volatge range and most new ones for either NiMh or NiCd. See http://www.batteryspace.com/index.asp?PageAction=VIEWCATS&Category=337 for a list of chargers. You can guess the voltage of your battery pack by counting ho many 'lumps' there are and multiplying it by 1.2 Each of those lumps is an individual battery all connected in series. Lead acid batteries are charged in a very different manner than NiCd and NiMh batteries. If it is lead acid, then it's probably in a squared off block of plastic and has the voltage and amp hour ratings on it. Find a lead acid battery online with those same ratings and you can use the same charging specs as the one online has. There's a way to calculate it but I don't know it off the top of my head.
Mar 18, 2008. 7:36 AMcomputerwiz_222 says:
Lead acid batteries are used in electric wheel chairs and scooters. They allow a pretty large current draw for the size they are. Read up on how to charge a lead acid battery through google. I usually just use a 12 volt wall power supply with two aligator clips on it. Although it is not ideal, it gets the job done. I just leave it plugged in for a certain amount of time. Usually 12 hours.
May 14, 2008. 9:05 AMDerin says:
do not forget the darn ups that also has a pb-acid in it i got a 12 v 9 ah out of a darn ups
May 14, 2008. 9:03 AMDerin says:
please call (800) Re-Use-Pb (738-7372) for disposal of lead acid batteries
Jan 27, 2008. 7:55 PMBeanBot says:
i have not read every thing but is this going to charge like a "single use battery" or what???.....
1-40 of 46next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:DoveP
