Step 6: Cut chain to desired length!
You will need two pieces that will equal your desired length. I have a very small neck, and I like my necklaces to sit pretty high, so I'm using lengths of chain between 8 and 9 inches.
The best way to measure for this is to loop the chain behind your neck, so you have one short end and one longer end hanging down your front, and determine what length suits you the best by pulling it back and forth, and then cut the longer end off.
Then you can double the chain and cut it in half.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
