3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Light Transmitting Concrete (+ HD Video)
Make sure to check out my blog!
I'm going to show you (as best as I can) how to make light transmitting concrete. Google it, and you will be amazed at how beautiful it is! I was desperate to get my hands on some...but considering the cost, I decided to make some with stuff I already had around.
This material has the strange effect of looking shiny or sparkly...but it's dull concrete at the same time! It's very entertaining to show off or play around with.
If this material interests you, check this article out:
http://www.impactlab.com/2009/03/07/litracon-see-through-light-transmitting/
Here is the HD video:
Here is the normal video:
Step 1Making The Mount
Making The Mount
 You need to roll some polymer craft clay into a flat circle. Make it as level as possible.
137 comments
1-40 of 137next »
Apr 7, 2012. 2:10 PMOgredude says:
This is an awesome instructable!  As soon as I saw it, I knew I needed to do a project with this technique.  But what to make? One of my friends owns a concrete supply company, so I put his logo in the concrete. He was very happy to receive it as a Christmas present!
I ended up having to make this thing twice. The first time, I really messed up the water to concrete ratio on the mix, and when I tried to demold it, it was very crumbly and pretty much fell apart.
http://flic.kr/p/bKoXPT
I took photos of the construction of the first one, but didn't photograph the second one until it was complete. I learned quite a few little techniques on the first try that made the second attempt go much easier, so I'll describe those techniques as I go.
I started with the clay base. Then I printed his logo in black on my HP inkjet printer, cut it out, pressed it onto the clay, then wet the back of the paper and dabbed it a bit with my finger. HP inks are water-soluble, so when you peel the paper away, it's transferred enough ink to see what you're doing onto the clay.
http://flic.kr/p/bKoX7T
The second time round, I decided that was still too hard to see, so I filled the design in with Sharpie. This helped a bunch.
I started putting fibers in one by one with plastic tweezers, but the fibers are so low-contrast that I had a very hard time seeing where they were going and where they needed to be.
http://flic.kr/p/bKoWn8
So I used a highlighter to color about the last quarter inch of the fibers, and worked under a blacklight, and I could see what I was doing just fine. The inked part of the fibers ends up in the clay, and it doesn't bother the finished piece.
I also discovered that an incense holder makes the perfect staging area for fibers, the ash trough makes it very easy to pick them up individually with the tweezers.
http://flic.kr/p/bKoWPg
After it was cast (and I fixed a crack with epoxy), I polished it up as best I could on a disc sander (killing 2 discs in the process), and covered it with several coats of triple-thick glaze.
http://flic.kr/p/bKoRoD
On one side is random dots of light...
http://flic.kr/p/bKoRPp
On the other, a logo!
http://flic.kr/p/bKoS36
Aug 18, 2011. 5:45 AMredorchestra says:
just to add a similar idea I recently heard.
My Cousin is in Peru helping villagers to add sky lights to their huts. They use a clear plastic pop bottle filled with water (clorinated to keep out green stuff)
It is embedded in the ceiling and sticks out of the roof. It channels sunlight into the hut and apparently lights up as well as a 60 watt light bulb. As long as the sun is shining!
Mar 24, 2012. 11:48 PMThaikarl says:
here's the link to the project. i made one for our shed here in thailand, it's so simple but works wonderfully! http://isanglitrongliwanag.org/
Jan 17, 2012. 5:39 PMerronius says:
My friend Karl (KR/RL to the rest of the world) and I have started putzing around with fiber optics in a fine concrete or mortar. KR/RL scanned a small relief his friend made from one of his unique figure drawings and had the scan printed into a large styrofoam (polystyrene for the Brits?) negative. The styrofoam served as both a mold for the concrete and a soft substrate to poke the optical fibers into.
you can read about the process on Karl's blog at:
http://krrrl.blogspot.com/2011/08/august-8-2011.html
Mar 19, 2012. 5:43 AMOscelot says:
Nice project!
Mar 8, 2012. 12:51 AMRienei says:
Hi, may i know if the following 2 works :
1) Sticking the fibres into the concrete AFTER pouring the concrete into a mould,
and
2) having less space in between the fibres to allow more light to pass through
Thank you in advance :D
Mar 19, 2012. 5:40 AMOscelot says:
I doubt sticking the fiber into the concrete afterwards would work too well, you'd get concrete on the ends and end up with it looking fairly dull, in my opinion. I don't see why you couldn't stick as many fibers in as you want to. Just my opinion.
Aug 20, 2011. 7:27 PMchibisuke11 says:
can i use white cement? please reply ASAP :)
Jan 17, 2012. 6:13 PMerronius says:
You may want to try to find a book called Sculpting With Cement by Lynn Olson. He uses white cement extensively on the outside of his concrete sculptures
Dec 14, 2011. 4:44 PMDeeRilee says:
I think I might try making the "bowl" of a birdbath this way! It might make for some interesting sparkles of light on the ground surrounding it! (hopefully!)
Apr 1, 2010. 8:26 PM12beav says:
(removed by author or community request)
Aug 18, 2011. 9:13 PMbadpanda says:
Glass fiber optics would not be too fragile for this application, but they aren't likely glass fiber optic because it is too expensive for use in a toy that doesn't actually need to carry any kind of data, and for a toy like this the attenuation would not be a critical factor... attenuation is a measurement of how well the fiber transmits light. This is most likely POF or Plastic Optical Fiber, not the common silica based type used in telecommunications applications which is glass, and just about as flexible as the POF. (I worked for Lucent doing Dense Wavelength Division Multiplexing stuff for a few years, Google it :)
Dec 30, 2010. 4:04 PMjosephlebold says:
I must say out of the hundreds of decorative fiber optic devices I have never seen glass fibers used. They would be too fragile.
Aug 18, 2011. 6:25 PMsillyzombie666 says:
real fiber optic cables use glass fibers
Aug 19, 2011. 9:37 AMjosephlebold says:
yeah I know, they use fake fiber optics in the fiber optic christmas trees and anything one can purchase at a store with fiber optics.
Aug 18, 2011. 3:22 PMpbecker83 says:
Pretty neat. I'd like to see some night time video.
Aug 18, 2011. 11:22 AMLMas says:
Really nice project!!!!
Aug 18, 2011. 7:40 AMDiscoInferno says:
Oh my... "Light" project are always interesting.
Apr 24, 2011. 8:43 PMerronius says:
LOL: agggh! another excuse to make a variant of the infamous Austin Powers Tent Scene!
Here are a couple other things i was thinking abewt:
1) if you want uniform light transmission, maybe one could use a mesh or some such thing to distribute the fibers evenly over the surface.
2) Well, what about non-uniform light transmission????!!! Sounds like something with real potential to me. What if you varied the density? You could create areas of gradient,highlight or shadow or an entirely new design or swirly pattern within your piece, which could really add an interesting dimension to a sculptural piece that was a low- or medium-relief.
Aug 18, 2011. 4:45 AMtgrundle says:
you could also leave the extra length on the fibers and use something (like paper or thin cardboard) to block some of the fibers from others and using led's light different sections with different colors. this could make a great yin-yang effect with the circle that was made in this ible.
Aug 18, 2011. 3:08 AMwobbler says:
Instead of making the clay into a flat circle, you could first make it into a long square profile strip. Then place your fibre optics all along the length of one side on the top surface. You wouldn't need to push them in, simply lay them on the top, so it should be quicker. You could then lay another long thin bit of clay on top to hold them if needed. This could then be rolled up to create a spiral. Alternatively, you could lay this out in a shape and then fill in the gaps with either wax or more clay before pouring the concrete.
Jul 6, 2011. 4:20 PMphapboy says:
SO COOL! Now I wanna see someone mash this project and this project!
May 16, 2011. 5:40 AMMissCindel says:
I like the image as it is held up to the light ... and started thinking that the fiber optic strands could be assembled in the clay in a pattern too :*)
Apr 24, 2011. 8:10 PMerronius says:
So you used an amended plaster, like hydrocal or ultracal? That's pretty interesting. Looks like you could do any kind of piece that has low relief.
You know, if you want to color the material, you don't necessarily have to use paint. You could conceivably use a colorant, like iron oxide (or one of those marking powders they use for carpenter's chalk lines, some of which are iron oxide) or a mason stain (sold at ceramics places) and mix it into your goop. If you are using cement, you can make it brighter and less gray by using white Portland cement instead of the ordinary dingy gray variety.
Mar 30, 2010. 10:25 PMBroom says:
I'm suddenly thinking of a concrete countertop, lit from below! OK, it won't be bright enough to see by, but super-cool accent lighting. Or - the most awesome bar counter ever!
Apr 4, 2011. 9:37 AMrubyintherough says:
Did any of you ever do the glass in counter-top?
I'm searching for a way to clean up the crushed glass from the recycling center to use. It's got too many label bits stuck to the glass.
Apr 11, 2011. 8:34 AMBroom says:
Put the glass in a roasting pan, and cook in the oven at the highest temperature (clean mode, if you have it) for an hour or two. The labels will turn to ash.
Jun 8, 2010. 2:22 PMMoralito says:
Bar counter is the way to go....Simply awesome...
May 3, 2010. 6:42 PMValster says:
My tropical theme bar is finished except for the counters...  Remote light wheel with color change or twinklie effect?  Waves, palm trees, tiki head patterns?  The possibilities are endless!
Jul 8, 2010. 3:46 PMalin.sala says:
making the top of the counter from concrete with fiber optics incorporated like in this tutorial but insead of cutting the fiber short connect them as bunches to a light source, like a light engine with a controller and you can make your bar rock!!
Apr 2, 2010. 6:24 AMhishealer says:
 Not only that, but you could spell out Welcome or make pictures with the "pixels"...
Apr 5, 2010. 7:46 PMtanmanknex says:
Combining that with mrfusi0n's idea above, that would be really cool.
Apr 1, 2010. 2:44 PMitwasalan says:
It would be really cool if the fibre optics could cause glass aggregate in the concrete to glint or twinkle too.  I was going to do concrete counter tops in my kitchen anyway.  Time to do some proof of concept experiments.
Apr 7, 2010. 3:30 PMdrakesword says:
what about a layer of fine crushed glass on the side facing up?
I made some fine crushed glass with a capped steel pole and a baseball bat. Just pound away until its like a dust.
Apr 1, 2010. 2:04 PMdfc849 says:
http://www.instructables.com/id/How-to-Build-a-Polished-Concrete-Desk/
Apr 1, 2010. 9:32 AMBroom says:
Not the point. The light is coming from below, making everything on the counter backlit, and therefore (I bet) darker by contrast than if the counter weren't lit.
May 3, 2010. 6:46 PMValster says:
Broom, I just realized how awesome drink glasses will look when lit from underneath.  I have to do this!
1-40 of 137next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
315
Author:nepheron(MakerWeekend)
I have an awesome blog @ www.makerweekend.com Im Calvin Drews, and I love to learn, experiment, invent, create, repair, and generally just do things myself. A sort of modern jack of all trades, mast...
more »
