Step 4Placing The Fibers
I used pliers. If you use them,too, be mindful not to crush the fibers...they are quite fragile, even though they are plastic.
3 Simple Ways to
Share What You Make
Other ways to share:
Painting with Colored Cement
by
Thinkenstein
Patch Cracked Concrete
by
Sakrete
Enclosure for a Generator
by
northernmenace
How to Patch Floors or Concrete Surfaces
by
Sakrete
Put a Rounded Roof on a Square House
by
Thinkenstein
Concrete Paver Floor
by
markbyounger
How to Pour Anchor Cement
by
Sakrete
Stop Leaks in Concrete
by
Sakrete
78,107
views
Related: concrete, light, transmitting, make, homemade, see through, cement, window, design
Comments: 135
Rating: 4.29
© 2012 Instructables
All Steps Viewing
Or maybe you could build a rig out of plastic; make a top and bottom piece with evenly spaced holes in them and thread the fiber optic through both, and then mount the rig inside a mold and pour the concrete. Maybe stretch clingfilm over the bottom piece before threading through the fiber. Don't know if it would work, but it could make larger scale production easier.
with a single longer tine and a small bifurcation to push the hair into place. we were punching hair into silicone or foam latex, though.
maybe if you used painter's canvas and either laid a dot pattern out or just punched the little fellas through how ever maybe a little UMR or spray release so the canvas doesn't bond to the cement.
awesome Ible, nepheron!
A layer of wax
A piece of screen raised quarter of an inch above that
Fill every hole with 1 strand
pour wax until it covers the screen
and finally cement
great idea, drakesword!
y'know it occurred to me.... those little polywhisker light guys, if you attached them to LEDs (or didn't trim them off the light source) and made a quicky mold of an inflatable ball, then cast them in as a quarter or half dome ( 1 1/2" walled hollow)
you'd have a very pleasing nightlght or sconce, i could even see using the pumpkin-stencil idea in conjunction with your fiber segregation screen idea to create awesome picture lights...
seems like it would make it easy to do ben day dots & halftone patterns too!
I'm going to try it.
First picture is a typical flagstone. Some are perfect squares. I don't like that!
Imperfection is cooler
Second picture is the box.
There is a single piece in it which can be placed and moved depending on what shape I want.
I want each stepping stone to look unique so i will have to make the dividers movable
The third is of a light on the optic fibers held together with my hand (the uv light shows up so bright on camera!)
