Step 6Breaking The Mold
3 Simple Ways to
Share What You Make
Other ways to share:
Painting with Colored Cement
by
Thinkenstein
Patch Cracked Concrete
by
Sakrete
Enclosure for a Generator
by
northernmenace
How to Patch Floors or Concrete Surfaces
by
Sakrete
Put a Rounded Roof on a Square House
by
Thinkenstein
Concrete Paver Floor
by
markbyounger
How to Pour Anchor Cement
by
Sakrete
Stop Leaks in Concrete
by
Sakrete
78,178
views
Related: concrete, light, transmitting, make, homemade, see through, cement, window, design
Comments: 135
Rating: 4.29
© 2012 Instructables
All Steps Viewing
Perhaps, while it's still in the mold but cured a number of hours, you can spray something such as spray-on silicone or even PAM, onto the surface that still has fibers sticking up out of it, and lay down a second layer of cement, let that cure, and then separate both.
Perhaps twisting the 2 pieces at the separation point, or running a long blade (such as a hacksaw blade) between the two would separate it without breaking the strands - not sure, maybe the lubricant would cause the fibers to slip right out of the concrete, but it might be worth testing out. If the fibers get a bit damaged from whichever method you separated them with, you're going to sand it down anyhow, so you'll probably end up sanding past the frayed parts.
Thanks for the fantastic Instructable!
Or build the mold so it forms on its side with the clay going up the middle and both ends?
like this
{|__[]__|}
Mold Clay Cement Clay Cement Clay Mold
