DIY Lightbox build with Ikea Lack table. by thebunnykingofnowhere
Featured
I have  wanted a lightbox for years, I live in a small flat and don't have the space to store a large lightbox. I decided to build a photo/tracing lightbox into my Ikea coffee table. I picked up all of the equipment on ebay and put the whole lot together in a couple of hours. The table is an Ikea 'Lack' and cost about £5, they come in many different colours.
Step 1: Choosing Correct Acrylic
-Ideally I would have made the top from one single thick sheet of acrylic with a routed out step around it's edge. However to do this I would need a router and a acrylic cutting router head... which I don't have. Instead I ordered two sheets of Acrylic. One 8mm thick transparent  sheet and one 3mm thick Opal coloured sheet. I had the clear sheet cut slightly smaller (which the acrylic company did free of charge).
-Lack table top measures 550x550mm
-Clear Acrylic 8mm 480x480mm
-Opal 3mm Acrylic 500x500mm
-I purchased these materials on Ebay from trentplastics.co.uk, they gave me cheap combined postage and next day delivery.
Throcken says: Apr 11, 2013. 6:16 AM
This is just awesome. Already commented on another lack light hack that I have to make one for lightbox purposes. Then I found your instructable! I have to give this a try!
GorillazMiko says: Mar 15, 2013. 2:47 PM
Beautiful. I'll add this to my "to-make" list.
mstaples3 says: Feb 6, 2013. 4:24 PM
This is awesome. Definitely going to be the final fate of my current lack table.
Could i ask you how much both sheets of plastic combined cost you in the end?
Mr_o_uk says: Feb 9, 2013. 4:37 PM
I got mine from the same place and paid ~£29 delivered.
Mr_o_uk says: Jan 20, 2013. 1:18 PM
Here's some pictures.
http://www.flickr.com/x/t/0099009/photos/61654338@N02/sets/72157632572246406/
Don't know how to post them on here (I'm on a phone).
I didn't take any photos inside before doing it all up which is a shame, but the connector is glued around the hole on the inside and also to the leg support.
I was going to have it flush, but there wasn't room between the Perspex and the bottom, so had to push it through a few mm. It made it stronger and tidier though.
I like the fact that the opal is smaller than the top, that and the screws, makes a feature of it. A flat complete top would look too plain in my eyes...
thebunnykingofnowhere (author) says: Jan 20, 2013. 2:26 PM
The table looks fantastic!
I hope it serves you well.
Mr_o_uk says: Jan 20, 2013. 9:46 AM
I just spent the afternoon making one of these out of a white table.
I think painting it white inside is a must. I used 2 tester pots from b and q as i didn't want to buy a brush or pot of paint. Each tester pot (50ml) did one coat. I gave it two coats.
The hardest part was the drilling of the Perspex. I think I would go slightly bigger on the Perspex (maybe add 5/10mm all round to both sheets) as I found the fixings were very close to the edge of the clear Perspex, and so one corner broke off a little (makes no difference as it doesn't move on the plane as its sat in a recess so that fixing is only holding the clear one down).
The only changes I made were...
1. using washers under the fixings (I still used the dome screws like you as I liked the look of them) but I wanted to spread the load a little!
2. I didn't like the hanging cable connector, so instead drilled a hole the size of the connector just off one of the leg supports, so that I could just poke it through a little and then glue the rest of the connector to the leg support so that it was solid.
Got the LEDs and power cable from eBay. £12.
Paint pots from b and q. £2.20.
Perspex from Trent plastics. £29.
Table. Free.
So £45 total. Not bad for a light box that size!
All in all, was a good instructable, Thanks!
thebunnykingofnowhere (author) says: Jan 20, 2013. 10:17 AM
Fantastic!
Congratulations on the build, would be fantastic to see a picture! I like the sound of your power cable modification. I would especially like to see what that looks like. I had considered at one point making the Perspex the same size as the whole top of the table and just glueing it down on top, I ended up deciding against this as I wasn't sure if the Perspex would be cut perfectly square. Id like to see someone do this with a white table as the light box would almost be entirely hidden. SO MANY POSSIBILITIES!
trishas5 says: Jan 17, 2013. 11:28 AM
This looks wonderful for my preschool class! We love using our light box for various activities. Most light tables/boxes for schools are lined/painted with silver instead of white. Do you think that would make a difference in the reflection of the light...making it show through the top more instead of being absorbed by the white paint. Since it's such a shallow space I'm not sure it would matter?? Also, I was thinking of just getting a rope light or fluorescent lighting. What are your thoughts on that? I'm kind of "building impaired." :) Thanks so much!
thebunnykingofnowhere (author) says: Jan 17, 2013. 12:41 PM
Hello the Trishas5!
I'm glad you like the project, I can certainly understand your students loving light boxes. They are surprisingly useful. You are absolutely right about silver being a better reflector, however silver objects reflect SO well that the reflection almost exactly mirrors the light source. Ideally the light in a light box is diffused and spreads evenly across the drawing surface, you don't really want to be moving the paper around the board to find the best light spots. Although the acrylic sheet helps the diffusion you would be surprised how much of a difference the white interior makes.
I considered using fluorescent lighting however it gets extremely hot and there simply isn't enough space inside to allow proper air circulation. The table is only 5cm deep and I think the plastic would melt pretty quickly. Rope lighting should do the trick though! Most rope lighting is LED based so you don't have to worry about the heat issue. Have a look on eBay for different options because LED lighting is INCREDIBLY cheap. I bought 5 meters for less than £10. Hope that helps!
shoerice says: Dec 22, 2012. 12:50 AM
I love this! In the midst of building one but my area only offers acrylic sheets up to 3mm thick. Will stacking 2-3 layers clear for the bottom work?
thebunnykingofnowhere (author) says: Dec 22, 2012. 2:37 AM
Hello Shoerice! Glad to hear you're having a crack at it yourself! I had a similar issue when I decided to build mine. I went to a specialist acrylic dealer and asked them what they thought about stacking several sheets up (because it was cheaper than a single thick sheet) They thought it wouldn't work as well. they pointed out that any dust or dirt that got in between (which is hard to avoid because the sheets generate static)would show up really clearly. I also suggested glueing them together and they had similar reservations. HOWEVER I still think that it probably would have worked reasonably well. The table top might end up being slightly more flexible and I would probably use 3 clear acrylic sheets for the bottom and 1 opal acrylic sheet for the top. If flexibility did turn out to be a problem I think you could probably construct a small supporting piece from acrylic for underneath. Failing that you could try eBay for 8mm acrylic. Even with postage it was much cheaper than my local specialist.
Best of luck with the build! Be sure to post pictures when you're done.
Cheers
Adambowker98 says: Nov 18, 2012. 5:50 PM
Can I just use white acrylic rather than the opal?
thebunnykingofnowhere (author) says: Nov 19, 2012. 12:14 AM
Good question, To be honest I don't know. You could buy a small sample and test it although I get the feeling that it'll be too opaque. The opal stuff is perfect because it's actually designed to let light through. You want it to be as bright as possible.
KingPeter says: Sep 16, 2012. 7:04 PM
Any one have any good places to pick up some Acrylic sheets in the Colorado area. Or any good websites?!?
Thanks
derte84 says: Apr 25, 2012. 6:47 AM
LOVE IT! I added to my famous guide 'HACK THE LACK' and for sure I'll make it in the near future
thebunnykingofnowhere (author) says: Apr 25, 2012. 11:21 AM
Fantastic, Thanks very much for adding me to the group! Make sure you post the pictures if you do make one.
Cheers
juliatheninja says: Apr 15, 2012. 10:28 AM
I think I'm going to make this, or a smaller version out of something else.
I've always wanted a lightbox!
Thanks for posting this!! :D
thebunnykingofnowhere (author) says: Apr 20, 2012. 11:39 AM
Make sure you put some pictures up! Would love to see some other versions!
steliart says: Apr 20, 2012. 3:06 AM
Very nice instructable “thebunnykingofnowhere” and very well presented.
I would like to add a few tips of a slightly different approach.
As an old school graphic designer I used light boxes most of my life, not just for viewing transparencies (slides or films) but to also use them as montage tables.
The difference from the ones I build (of this size) is that I used a circular fluorescent light (remove all its components from the metal casing and remount them inside your table/box), then I glued some wooden stripes on the inside perimeter to create a step deep enough to hold flash a white acrylic sheet and a glass top over it. Open a few big enough holes at opposite box sites for air ventilation and to cool it down. No screws are necessary as the weight of the two tops will keep it in place nicely and flash, also it’s easy to remove and change the fluorescent if needed. Some times if the diffusion is not enough you may add a sheet/s of tracing paper between the acrylic and the glass or use a white glass. At the site you can mount an on/off small light switch.
thebunnykingofnowhere (author) says: Apr 20, 2012. 11:38 AM
Thank you Steliart,
It's nice to hear everybody's different approaches. I was thinking about using a fluorescent ring as that's what they have at the photo lab where I work. However it does get very hot and I was a little worried about mounting it in a table which is only 50mm thick. I think if I built one from scratch then that's what I'd do.
Cheers
anke-art says: Apr 19, 2012. 2:28 PM
Wonderful project, what a bright idea (yeah, lame pun).
meldinov says: Apr 19, 2012. 8:06 AM
Nice instructable.
I really dont know a lot about lightboxes, but why do you need 2 acrylic sheets?
doesnt it work just as good only with the opal one?
scrutables says: Apr 19, 2012. 10:49 AM
It's so that it nests nicely inside the table- structural, not functional.
thebunnykingofnowhere (author) says: Apr 19, 2012. 11:22 AM
That's right, I wanted to use one single sheet with a routed edge but I don't have the tools necessary. I also sort of thought that using a thin layer of opal and a thick layer of clear would allow more light to pass through. Less diffusion etc...
Oh and also they only seem to make Opal acrylic up to 5mm which is a bit to thin.
augur45 says: Apr 19, 2012. 11:01 AM
How do I nominate you for "best idea of the year" award?
foobear says: Apr 19, 2012. 10:39 AM
cuckoocool
thebunnykingofnowhere (author) says: Apr 15, 2012. 1:23 PM
Cheers guys! It's my first instructable so I'm pleased it's so popular. Hopefully it will help some people out. HACK THE LACK!
Jason Bedard says: Apr 15, 2012. 1:15 PM
This is my favourite IKEA hack yet.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
