DIY Lockring Pliers
40,714
65
31
Posted
Introduction: DIY Lockring Pliers
You can buy different types of tools to remove the lockring from a fixed gear track bike. Some are the spanner type and some are pliers. I like the pliers best but I don't want to shell out $30-$50 for a set so I decided to make a set.
Step 1: Gather Your Weapons!
First thing is to buy some pliers. I bought a cheapo set from Menards for $5 and they worked great. Just make sure you buy a big enough set that they'll open wider than the locking and still have the jaws parallel to one another.
You'll also need something to file the metal, I liked to use a hand file but you could also use a dremel tool with a stone wheel. The cresent wrench in the picture is to take the pliers apart, you probably don't have to take them apart but I thought it made it easier.
Step 2: Dremel or File the Teeth
Get to work cutting down the teeth, leaving the front bit of the pliers to fit into the notches of the lockring. Take your time and try to get them to fit as tight as possible and get the teeth to fit into the notch as far as possible so that they won't slip off.
Step 3: DONE!!
When you get done they should look something like this. When you go to use them just fit them in the notches, give them a good tight squeeze and crank the lockring off. Remember that the lockring will be reverse threaded, don't rip the threads off of your hub.
  • Microcontroller Contest
  • Trash to Treasure
    Trash to Treasure
  • Science of Cooking
    Science of Cooking
30 Comments
Technically, you've modified channel locks not "pliers."  Other than that, well done!
"Technically" they are slip joint pliers (also known as water pump pliers). Channel Lock is a brand name.
Nicely done russd32.
Touche!  Well played, sir, well played :-)
Theoretically, the same concept could be applied to a set of Vise-grip brand locking pliers.  >random heckling from the crowd<
Reminds me of the "Vise-Whip", which is an alternative to a chain whip that operates like locking pliers.
Necessity is the mother of invention, hence Specialized tools.
I was just thinking the same thing, with the benifit of being able to lock them on!
great bit of thinking here though,hats off.
Excellent! You saved the day, thanks a bunch
I'm going by the hardware store on the way home to buy a set of channel locks so I can build this. It's a brilliant project. Thanks
Made a set for myself today out of El Cheapo Pliers from Harbor Freight. Great Idea and thanks for saving me some money!
Yours looks better but it all works the same I guess. :P
