3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Lockring Pliers
DIY Lockring Pliers
You can buy different types of tools to remove the lockring from a fixed gear track bike. Some are the spanner type and some are pliers. I like the pliers best but I don't want to shell out $30-$50 for a set so I decided to make a set.
Step 1Gather your weapons!
First thing is to buy some pliers. I bought a cheapo set from Menards for $5 and they worked great. Just make sure you buy a big enough set that they'll open wider than the locking and still have the jaws parallel to one another.
You'll also need something to file the metal, I liked to use a hand file but you could also use a dremel tool with a stone wheel. The cresent wrench in the picture is to take the pliers apart, you probably don't have to take them apart but I thought it made it easier.
26 comments
Feb 19, 2012. 4:04 PMapplesaucemodifier says:
Made a set for myself today out of El Cheapo Pliers from Harbor Freight. Great Idea and thanks for saving me some money!
Yours looks better but it all works the same I guess. :P
Aug 11, 2010. 5:46 PMsprinks says:
I just made one the other day with my bench grinder and a spare set I had laying around. Thanks for the instructable, this will make a great tool to keep in the bike tool box and a nice replacement for my missing pedro trixie multitool.
Feb 28, 2010. 5:50 PMtisit1 says:
in the land down under we call them Multi Grips so there you go self explanitory Aussie Aussie Aussie oi oi oi
Feb 28, 2010. 1:36 AMmaxlycos says:
Very good idea. Thanks for sharing.
Feb 27, 2010. 8:48 PMprofpat says:
 very clever, yes, this is a cheap alternative...
Feb 26, 2010. 1:44 AMtrgz says:
I have two pairs of those type of pliers and a couple old bikes without sealed BB's so I may well be doing this myself. Could be good for old -style headsets too. Nice one.
Feb 23, 2010. 10:33 AMJur says:
Nicely done, clear and easy instructions for a very good result.
Can you still use them as slip joint pliers/water pump pliers/channel locks/polygrip, or are the teeth filed away too much?
Feb 25, 2010. 5:50 PMshiftrk says:
Great job this will come in handy
Feb 25, 2010. 9:08 AMasibonzai says:
Very cute idea for old lockring pliers.
Thanks.
Feb 25, 2010. 8:23 AMdesertdog says:
Very interesting mod for pliers (note that I did not enter into the game of naming them specifically).  I bought a "cotter pin pliers" from Sears many years ago.  They are pretty much the same as what you did.  Possibly  the most useful tool I have ever bought.  Don't think they sell them anymore.
Feb 20, 2010. 4:35 PMascii says:
Thanks - that's a nice, simple hack that I wouldn't have thought of.  Modifying tools is one of the more rewarding things one can do.
Feb 18, 2010. 10:23 PMkelseymh says:
Technically, you've modified channel locks not "pliers."  Other than that, well done!
Feb 19, 2010. 6:46 AMhammerpb says:
"Technically" they are slip joint pliers (also known as water pump pliers). Channel Lock is a brand name.
Nicely done russd32.
Feb 19, 2010. 1:23 PMdeathpod says:
(removed by author or community request)
Feb 19, 2010. 10:55 PMhammerpb says:
That is actually incorrect. There are slip joint pliers that have 2 positions, but they are not the only type. they are by far the most common, however. Every cheap, and most expensive, tool set you buy, almost without exception will have the 2 position  straight jawed pliers . I even have a set of those that has 3 positions (not grooved, but 3 overlapping semi-circles like the 2 position ones). some of the first multi position Channel Locks were designed like this as well, until the tongue and groove type was proven to be superior in almost every way. to this day, you can buy a cheap imported set of water pump pliers that use the overlapping circle design.
Feb 19, 2010. 1:26 PMdeathpod says:
Channel lock  calls them tongue and groove pliers
Feb 21, 2010. 4:36 PMjack002 says:
OMG, shuddup already. you both are right and wrong.
Feb 19, 2010. 6:59 AMkelseymh says:
Touche!  Well played, sir, well played :-)
Feb 19, 2010. 7:23 AMcaitlinsdad says:
Theoretically, the same concept could be applied to a set of Vise-grip brand locking pliers.  >random heckling from the crowd<
Feb 19, 2010. 2:12 PMrimar2000 says:
Clever!
Feb 19, 2010. 1:47 PMDIY Dave says:
When I first read the title, I thought it said "DIY locking pliers". I thought you were making a pair of vise grips from channel locks.
Feb 19, 2010. 9:21 AMkissiltur says:
that is brilliant!, and so simple!
Feb 19, 2010. 4:18 AMlemonie says:
That's simple, and so nicely done.
L
Feb 18, 2010. 11:06 PMtrayo says:
Awesome. I will definitely keep this in mind for the future.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:russd32
