We’ve literally dropped bowling balls on it to test its toughness.
Ideum, a New Mexico-based company, built and sold MT50 multitouch tables between 2009 and 2010. There are dozens of these tables installed in museums, research labs, and a few are even installed at Fortune 500 companies across North America. The MT50 has been discontinued, as of March 2011, and has been replaced by a LCD based table, the MT55 HD (you can learn more about the MT55 HD on the Ideum website: http://www.ideum.com/products/multitouch/). It is worth mentioning that many of the techniques used in the MT50 are still used for large-scale installations such as walls, multiple projector tables. While the MT50 documentation is no longer available on the Ideum site. A description, videos, and reviews can be found on the GestureWorks website:
http://gestureworks.com/features/supported-hardware/ideum-mt-50-multitouch-table/
The instructions for the MT-50 are being released as part of the Open Exhibits, museum software and hardware initiative. Open Exhibits multitouch and multiuser software is free to students, museums, nonprofits, and US Government agencies.
If you have any suggestions for how we might improve these instructions, please let us know.
The Ideum and Open Exhibits Team
Corrales, New Mexico
Remove these ads by
Signing UpStep 1Assembling the Aluminum Frame
Pacific Integrated Handling Inc
480-379-0100 (phone)
Ideum MT-50(200-05320) kit
The kit will come with all the needed aluminum strut, screws, T-nuts, and gussets that are needed to assemble the aluminum frame.
If you have ever played with an Erector set, you will be able to put together the Bosch aluminum frame very easily.
To assemble, you will need the following tools:
- 1 Metric 2.5 Hex Key
- 1 Metric 4 Hex Key
- 1 12mm Socket w/ wrench
The different thicknesses of aluminum strut will be referred to in millimeters. For the most part, the sizes in this kit are 45x45mm, 30x30mm, 20x20mm, and 20x40mm. This size convention also works for the Gussets (the triangular pieces that are used to connect strut). There will be 45mm gussets, 30mm, and 20mm.
You will need to refer to the drawing and strut diagram to put the frame together. The strut chart will show thickness, length, quantity, and a part letter. Use the part letter and the diagram to figure out which piece goes where. Do not attach the wheel assemblies until you have the bottom panel on.
Part F on the diagram needs to be slightly modified so that the wheels can be attached to it properly. A ½” hole will need to be drilled as shown in the image above.
![Enable mouse and keyboard functionality on an iPod Touch or an iPhone! [Linux]](http://img.instructables.com/files/deriv/F09/VY6U/G9GQGXFB/F09VY6UG9GQGXFB.SQUARE.jpg)
There are many interchangeable parts within the system that can be purchased for less. You can find some of these throughout the instructable.
