I usually use it to capture bar codes, words from newpaper magazine, name card, products and small object....if you like this video...kindly held to vote me higher...thank you and enjoy the movie...
There are all you will need:
1) Blu Tack (very little), about $0.1 buck
2) A pair of Presbyopia glass(must use 250 to 275 degrees) get one at 1 dollar Shop
3) 1 piece of pipe ring form any DIY shop, about $0.1 buck
Instruction:
all you need to do is blu tack....just watch my video instruction
Remove these ads by
Signing UpStep 1Tools we need
THIS INSTRUCTABLE IS FALSE ADVERTISING, CREATED TO DRIVE VIEWERS TO THE CREATOR'S METACAFE PAGE, UNDER FALSE PRETENSES.
this is precisely why metacafe instructables should not be allowed.
I'm very sorry to inform anyone who has tried this instructable and seen less than optimal results, but the author has been less than truthful about the results of his creation... although it may give perfectly acceptable shots, it did not provide the "sample" shots shown at the end of the instruction set.
Most digital camera's add textual data to a photo they take, what is known as EXIF data. It records the type of camera, the settings used, and the lens used in most cases. In addition, most professional/semi-professional image editing suites will leave this EXIF data alone, or append to it when editing and re-saving a document.
That sounds interesting enough, but what does it have to do with the proposed insidious nature of this instructable, you may be asking. Well, most of these images have no EXIF data attached, fair enough... it simply implies that they have been edited in a less advanced program. However, In two cases the EXIF data has survived... We will now examine the EXIF data for the photo of the ear, and the photo of the Book:
EAR
Camera Make: Canon
Camera Model: Canon EOS-1Ds Mark II
Image Date: 2005:01:17 17:48:50
Flash Used: No
Focal Length: 100.0mm
CCD Width: 1.73mm
Exposure Time: 0.0040 s (1/250)
Aperture: f/22.0
ISO equiv: 100
White Balance: Manual
Metering Mode: Center Weight
Exposure: Manual
Exposure Mode: Manual
Strangely enough, this shot appears to have been taken with a professional DSLR, using a 100mm lens. the entire shot does not have the narrow depth of field normally associated with macro photography.
BOOK
Camera Make: OLYMPUS IMAGING CORP.
Camera Model: X550,D545Z,C480Z
Image Date: 2006:12:09 21:59:39
Flash Used: No
Focal Length: 6.3mm
Exposure Time: 0.100 s (1/10)
Aperture: f/2.8
ISO equiv: 100
White Balance: Auto
Metering Mode: Matrix
Exposure: Creative Program (based towards depth of field)
This time, we appear to have an Olympus D545Z (which goes by a few other names in foreign parts), which is a 4 mega-pixel DSLR from years past. Surprisingly enough, this camera recognizes a focal length of 6.3mm, which implies that a professional macro lens is attached.
neither of these cameras look, in the slightest way, similar to the one shown. I am fully confident that the other images are just as much a falsehood, given the high-quality bokeh present in the images of the flower, caterpillar, and turtle(?), which a lens this bodged together has NO hope of achieving. Also, the image of the cat I am certain I have seen before, but I cannot remember where...
if you are interested in how to easily view an image's EXIF data on the fly, check out FXIF, a Firefox extension that adds EXIF data to an image's properties page.
(i have no affiliation with the creator of this plug-in, I simply use it)
/rant
That's really sweet, I've often wished Firefox had it built in, plug-in installed.
