Happiness in a Pill
22,904
68
13
Published
Introduction: Happiness in a Pill
About: "Almost Toast"
Forsooth Instructabrarians!
Here's a nostalgia trip for 90's fans.  Remember those dimestore Magic Grow animals and dinosaurs that you got when you would find in Safeway when you were a kid?  They came in blister packages and You would put them in water and then after a few seconds they would suddenly burst into a creative foam creature? And then sometimes you would laugh as someone mistook them for medicine and then swallowed them? Classic.
Well, as it turns out, somethings never get old.  After spending a few hours at the SAN FRANCISCO TECH SHOP, yes, I MADE IT AT TECH SHOP, I have successfully recreated this childhood past time, but with my own creative designs.  Thus we have my childhood Happiness In A Pill. For Emergencies Only!
Step 1: Inspiration
Magic Grow toys always fascinated me as a kid.  Not because I thought they were amazingly complicated or astounding, but by how simple they were.  Even as a child I knew they were basically just sponges haphazardly shoved inside a disposable capsule.  Nothing really groundbreaking here.
And yet, I still found them totally AWESOME.  So when I decided to make my own, I decided to create ones with some of my more adult interests now to continue my childhood fascination.
Step 2: Materials and Parts
Depending on the kind of tools you have at your disposal, this can either be a really easy instructable to a mildly challenging one.
There's really only two things you need for this project:
  • Off the counter, non prescription medicine (ie Echinacea)
  • Industrial Packaging Foam (or some kind of material that can fit inside a small capsule)
The only real challenge comes to what object you want inside the capsule.  In order to get the precise shapes I wanted for my foam, i ended up laser cutting them out from a giant block using'TECH SHOP's laser cutter.
However, if you want to make a much more simple instant grow pill, you can also write messages on plastic grocery bags and stuff them in instead.
Step 3: How It Works
The process for this instructable is simple.
  1. Carefully open up your "placebo medicine" capsule, removing the material inside the capsule without breathing any of it in (it's horribly foul).  Do not cut pill open, do not use scissors.  It must be able to be closed afterwards.
  2. Using a small stick, or something similar, shove your foam object inside the capsule.
  3. Close capsule carefully
  4. Get a bowl/ glass of hot water and place pill inside
  5. Watch the Magic Happen!
Step 4: Conclusion
I love this project.  It was exceptionally fun to make, and while the process wasn't particularly difficult this project never ceases to bring joy.  Horrible joy, the kind that screaming kids feed on continuously.
Anyway, spread the love with this projects!  Go make a happy Mac Icon in a pill for your computer company excursion!  Make a plethora of instant Cthulu monsters for your literary club!  Or, even better, use this pill to propose to a friend.
SHIFT!
    • Planter Challenge
      Planter Challenge
    • Stick It! Contest
      Stick It! Contest
    • Make it Move Contest
    13 Comments
    These are great! Did you know you can actually get just the pill capsules at some natural food stores? I found some at Whole Foods a while ago and that would probably be cheaper than buying the capsules already filled with something, if you could find them somewhere.
    I loved playing with these when I was about 4. Great Job!
    wow that project is really cool and i wonder what it does if i put one in my mouth
    i always wondered what would happen if you swallowed one of those grow pills
    Fun project, I remember these being so amazing when I was a kid. A question though: what's that foam made of? Is it safe to cut in the laser cutter?
    Hmmmm, I'm not quite sure what the foam itself is made of (except for saying "foam") but it is laser cutter safe, at least to a certain degree. Set your speed to 100 and your power below 20 and you should be fine.
    One should always check that materials don't give off fumes that are corrosive to the machine or toxic to humans. A bit more detail here: http://www.epiloglaser.com/tl_msds.htm
    you can buy empty capsules bulk at a health food store. At least, in Northern California you can.
    I love these things! My sister and I used to use them all the time. To bad I don't have a laser cutter. :(
    Oh man. If I can manage to make one of these that holds an outline of the spaceship Serenity, I will be the HERO of the next Shindig!!
    PM me your mailing address Browncoat and you're there!
    Really?! Well aren't you a Big Darn Hero! :D
    I loved this! Thanks for sharing!
    sunshiine
