for more pictures and DIY fun, go here: angelpeach838.wordpress.com
Remove these ads by
Signing UpStep 1Buy Materials
2. Toggle bolts (purchased at Lowes). The spice rack needs to be anchored to the wall if you're putting it into drywall. Mine we're 3/8".
3. Super Glue. I used E-6000 (purchased at Walmart?). The only thing I did not like about this was the drying time. At LEAST 16 hours. It was also stringy and had a tendency to get everywhere, although it did not become tacky right away, so that was good.
4. Neodymium magnets (purchased from eBay). I used 1/4" x 1/16". Next time I would go larger in diameter because I ended up having to use two magnets in order to make a full jar stick to the steel.
5. Spice Jars (purchased online). This is totally up to you. Personally, 4oz is PLENTY big enough. I probably would've gone for 2oz jars, but I couldn't find the shape I was really going for in 2oz (hex shape).
Tools:
Large drill bit, drill, screwdriver.
It can be done. :)
1) We were afraid with them hanging down that it would be easier to knock them off, but with a smaller jar this might not be as much of an issue.
2) I wasn't sure of the sturdiness of our cabinets if that makes sense. We had to put quite a hole in the drywall to anchor everything in place, and I really didn't want to do that to our cabinets.
I believe industrial epoxy or contact cement would hold it securely in place. I may be wrong too.
I have to say I am surprised that a couple of relatively small magnets can reliably hold up a glass jar filled with dry goods.
I don't see anywhere where you specify the magnet type, where to buy, of how to buy ones that are strong enough.
Can you please provide a bit more info.
Peter O
But they're neodymium magnets and I got mine from eBay very cheaply :)
This website was very helpful and lists the pull force for many different sizes of magnets.
KJmagnetics.com
Good luck! :)
