Introduction: DIY Mandrel Bender
Picture of DIY Mandrel Bender
Step 1: Tube Holding Blocks
Picture of Tube Holding Blocks
Step 2: Die
Picture of Die
I got a gear weld on blank and cut the profile of the 5/8 tube in it , using a 5/8 ball end cutter.
Step 3:
Picture of
Step 4: Making a Cut Out for Clamp
Picture of Making a Cut Out for Clamp
Step 5:
Picture of
Step 6:
Picture of
Step 7: Clamp Placement
Picture of Clamp Placement
Placed clamp to see how it fits now it's ready for welding
Step 8: Prep for Welding
Picture of Prep for Welding
Step 9: Welded
Picture of Welded
I tig welded the clamp to the die using stainless steel filler rod
Step 10:
Picture of
Step 11: Back in Mill
Picture of Back in Mill
I put the welded parts back into the milling machine indicated it straight ready for the cut with the ball nose cutter
Step 12: Blended in Ball Nose Cut
Picture of Blended in Ball Nose Cut
Step 13: Machine Clamp
Picture of Machine Clamp
I screwed in the opposite side of the clamp to the die in the vice so I can hold it ,so I can machine it with the ball nose cutter
Step 14: Finished Machining Clamps and Die
Picture of Finished Machining Clamps and Die
Step 15: Clamp
Picture of Clamp
I tested the clamp on a piece of .625" inch round tube
Step 16: Mandrel
Picture of Mandrel
To make the mandrel I'm using a piece of M8 metric threaded rod , I put two stainless screws on the end of it getting them ready to weld together
Step 17: Mandrel
Picture of Mandrel
After welding together I forged it with a hammer to harden it.
Step 18: Grinding Mandrel to Size
Picture of Grinding Mandrel to Size
Step 19: Grinding Mandrel
To bring it to the right size and shape I put the end of the threaded rod into a drill then I sanded it on a disc sander,
Step 20:
Picture of
Step 21: Finished
Picture of Finished
Step 22:
Picture of
Step 23:
Picture of
Step 24: Checking Fit of Mandrel
Picture of Checking Fit of Mandrel
Step 25: Tube Guide
Picture of Tube Guide
I machined a tube guide from brass
Step 26: Tube Guide
I drilled holes to mount onto a plate
Step 27: Tube Guide Support
Picture of Tube Guide Support
Step 28: All Together
Picture of All Together
Step 29: Crank Handle
Picture of Crank Handle
Step 30: Bottom of Crank Handle
Picture of Bottom of Crank Handle
I made a cut out for the tube clamp and a bored hole that locates the die
Step 31: Ready to Test
Picture of Ready to Test
Step 32:
Picture of
Step 33:
Picture of
Step 34: Worked Perfectly
Picture of Worked Perfectly
Step 35: Time to Make Some Parts
Picture of Time to Make Some Parts
Takdashark (author)2017-02-18
First off, amazing work! Ia little confused how the threaded rod mandre functions. I feel like I'm missing something. The rod would and get stuck in the part of draw through with it, so there's definitely something I missed or it magic!
redchapman (author)2017-01-19
This is really cool, thanks for sharing! Can I borrow that ball nose cutter? Haha.
I was searching around online and found these guys: https://www.highpurity.com/custom-fabrication/mand...
Would you recommend them as well?
rionela (author)2015-11-10
very good i was thinkung to make the die mobile or somthing like this ones
ARJOON (author)2015-10-20
impressive work but that tig weld :S
romulobc48 (author)2015-06-21
vincent7520 (author)2014-03-16
Only on Instructables can you find people crazy enough to make a bender that I'm sure works even better than the manufactured ones !!!…
Thank you.
This is perfect.
Again thanks for posting.
NovelUserName (author)2014-01-17
Very Impressive how well that works!
About This Instructable
117,564views
127favorites
License:
Bio: I'm an inventor , machinist , welder .
More by inventrob:DIY Mandrel BenderDIY Rotary Moulding Machine
Add instructable to:
