DIY Massage Ring
894
8
Posted in CraftJewelry
Introduction: DIY Massage Ring
About: Hello friends we are Abhay and Akshay of Meerut,India.We are twin brothers from india.We publish random instructables each fortnight.We like physical topics like electricity and magnetism.. We also love robo...
[Play Video]
Hello friends please Vote us In the Rings Challenge and Guerilla Design Contest...
Hello Dear Friends,
Welcome to our 13th Instructable...
Our mom had a bad pain in her index finger...
And Science says that best pain relieving thing is massage...
So we thought of making a beautiful ring that massages the fingers...
This ring doesn't use advanced electronics therefore it is easy to make this ring and it is cheap also...
DISCLAIMER: By using Instructables or any Service, you may be exposed to Content that is offensive, indecent, objectionable or unsafe. Each user must evaluate, and bear all risks associated with, the use of any Content, including any reliance on the accuracy, completeness, or usefulness of such Content. This disclaimer is a legal notice covering the injuries caused while working on this instructable. Do at your own risk and Do not play with tools.
So, let's make this beautiful ring...
Step 1: Go Gather Stuff...
Here is a list of materials needed...
• (x1) 3v Coin Cell
• (x1) Small toggle button
• (x1) Small Vibrating motor ( Salvaged from old samsung sgh x210 phone)
• (x1) 2.5mm diameter copper wire
• (x1) Printed attached Photo (in diameter 2cm)
• (x1) Small Rope Or Paracord ( Just a few centimeters)
• Some wires
Tools Needed-
• Soldering Iron
• Pliers
• Wire Cutter
• Glue
• Hot Glue
• A pair of Scissors
• Dremel
• Multimeter
• A Marker
Now let's Work on this Interesting project....
Step 2: Makin' the Ring....
First of all let's start with making the ring.....
First take the rope and measure the width of your finger (circumference) by looping the rope around your finger and then marking the length with a marker....
Then measure the same length for the copper wire and then cut it off from the required length....
Then take this wire and and then with the help of pliers make it round so that it becomes a ring.....
Now check the ring that if it is fitting properly in your finger....
If it's not make the desired changes with the help of pliers...
Now let's follow the next step.....
Step 3: Making the Circuit and Testing.....
[Play Video]
First connect the switch to the +ve of the motor and to the +ve of the coin cell...
Then connect the -ve of the motor to the coin cell...(follow the circuit)
And then solder all the connections...
And then test your circuit by pressing the button...
Watch ours working here...
Now place the components in the form of a circle and glue them...
Don't forget to place the button on the side of the cell...
Step 4: Assembling the Ring...
Now take the circuit in the shape of a circle and place it perpendicularly on the ring...
It should be placed correctly so that you can easily press the button..
Glue the copper ring to the circuit smoothly so that it looks nice...
Now cut the printed pearl photo and place it on the top of the ring and glue it there...
Fill up the empty spaces with hot glue...
And give the ring a smooth finish like a pro...
Step 5: Ready to Massage...
[Play Video]
Now after all these steps you must have a headache, haven't you??
So what are you waiting for just grab the DIY Massage Ring and massage your Forehead....
This li'l ring can make you painless anytime anywhere you want.....
Please vote if you like our Idea And Ible....
[Our Channel]
Thanks For Watching
Have A Nice Day.....☺☺☺☺
    • Slow Cooker Challenge
    • Spotless Contest
      Spotless Contest
    • Flowers Challenge
      Flowers Challenge
